2 Replies Latest reply on Nov 7, 2008 8:23 AM by bogiesan-gyyClL
    coloroma question
      i saw the tutorial about making a luma matt from this effect,
      but what is the actual use of this effect?
      and can you direct me to some tutorials about the usage of this feature?
        • 1. Re: coloroma question
          I have no clue what you are referring to. Matte modes are explained in the help files and as for usage - well, your other thread about your keying issue clearly shows what they would be good for. Mattes are nothing more than a different way of introducing and manipulating Alpha channels, just like masks...
          Mylenium
          • 2. Re: coloroma question
            bogiesan-gyyClL Level 3
            Using Colorama as a matte generator or controller is pretty advanced stuff. You need to understand everything Myl. has mentioned and then you must know how to set the transparency parameters for the colors you select in the Output Cycle.
            bogiesan
