4 Replies Latest reply on Nov 10, 2008 11:48 AM by Mylenium
    Sizing PSDS for After Effects / Preparing Illustrator files for After Effects
      3 questions
      For the longest time I have been told when importing PSDs to
      After effects, in order to keep circles circles (proper ratios) I had
      to make a 720 540 PSD file and then crunch it down to 720 486. Then import the file to a D1 NTSC 720 486 after effects comp and everything works fine.And it does and always has
      I have now been told otherwise. People claim they view in DV NTSC view
      in Photoshop at 720 486 and then just import to a 720 486 DV1 After
      Effects comp and everything is fine.
      That view mode in Photoshop is for viewing purposes only though so this
      confuses me. Sure you can sit there and stretch your picture to look
      right in that mode but that doesn't make sense. Going 540 to 486 is
      quicker.
      But one weird thing I noticed is if you save your PSD with the NTSC
      view mode turned on it will automatically import to After Effects with
      DV NTSC comp settings. Otherwise it will import into a Square Pixels
      comp.
      So to simplify my questions are the following.
      1. Is there a way to avoid creating a 720 540 PSD and then crunching
      down to 486? And somehow keep circles circles and photographs not
      stretched.
      2. Why does the DV viewing mode in Photoshop effect the importing into
      After Effects if it's just for preview purposes?
      That said I like that viewing mode in Photoshop because when I do my
      720 540 to 720 486 crunch I can see that everything will look fine.
      If anyone can help it would be much appreciated. I've been fine doing what I'm doing but for the last couple years I have been told there's a quicker way and haven't found anyone who knows.
      And my final question #3 is
      How do you import an illustrattor file into After Effectcs with
      layers? I know how to bring sa photoshop file in with layers but everytime I import an illustrator file in , it comes in flat as one layer.
      Thanks very much to those who can help.
      J.
        • 1. Re: Sizing PSDS for After Effects / Preparing Illustrator files for After Effects
          >stretched.
          Not really and then "crunching down" is very much a matter of point of view. The real question is: Can you accept the variations e.g. in antialiasing introduced by creating your work with non-square pixels in Photoshop. Apparently doing so will affect horizontal sampling more than vertical and as there is a difference in how AE and PS deal with these matters, the result would be different. It also extends to the matter of how practical it would be to work with such files if you need to move them to applications that don't provide PAR correction...
          It doesn't. The people told you only half the facts. Photoshop's PAR correction is just for viewing purposes, that's true, but it does not mean that PS itself would be unable to deal with non-square pixels. Whenever you create a files based on such presets, PS will correctly embed that information for saving, hence programs like AE that are able to extract that information, will use it to correctly interpret items.
          >layers?
          You can't. In the strict sense Illustrator has no layers, only objects and groups and since they can be infinitely combined in the funniest ways, it's a hell of a thing to read them right. Maybe in CS5 after all these years... (or even later).
          Mylenium
          • 2. Re: Sizing PSDS for After Effects / Preparing Illustrator files for After Effects
            Todd_Kopriva Level 8
            I'll answer the easiest question (#3) first:
            When you're importing an Illustrator (.ai) file, are you choosing Composition (or Composition - Cropped Layers) from the Import As menu in the Import File dialog box? Or are you leaving the setting at the default of Footage? (See "Import a still-image sequence as a composition".)
            If choosing one of the Composition options isn't working for you, then this we'll have some troubleshooting to do.
            • 3. Re: Sizing PSDS for After Effects / Preparing Illustrator files for After Effects
              Regarding question #3:
              You can import an Illustrator (.ai) file with separate layers. Just make sure that you have Composition (or Composition - Cropped Layers) selected in the Import As menu in the Import File dialog box. If you instead have the default Footage option selected, then all of the layers get merged together.
              (See the "Import a single still image or a still-image sequence" section of After Effects Help on the Web.)
              If choosing Composition from the Import As menu doesn't work for you, let us know.
              I think that what Mylenium was thinking of is the inability to import an Illustrator file with each object on a separate After Effects layer. That would be a very good thing, and it's a common feature request. (If you want to add your voice to that feature request, please fill out the feature request form.)
              If you're working in Illustrator for the purpose of bring items into After Effects, you'll really want to keep objects on separate layers in Illustrator so that you can animate them separately in After Effects.
              • 4. Re: Sizing PSDS for After Effects / Preparing Illustrator files for After Effects
                Yepp, my mistake. I always confuse this kind of stuff. Doing too little with Illu, apparently. ;-)
                Mylenium
