3 Replies Latest reply on Dec 10, 2008 7:45 AM by (KarolPL)
    PC Win XP AE 7- Bad audio quality
      I'm working with AE 7. My problem is, that when I export audio project as *.wav (or render as wav file), the quality of final track is bad- music is distorted in some places, some strange pops occures. I've tried everything- from playing with AE audio settings, to making a new sound track in adobe premiere (It doesn't works, AP 6.0 just crushes when too much sound files are put into it).
      Opearting System: Windows XP
      Sound card: Sound Blaster Audigy + Creative EAX drivers
      Is it fault of program, codecs or maybe sound card? What i have to do to fix it?
      Thanks in advance- I would like to render my movie before x-mas.
        • 1. Re: PC Win XP AE 7- Bad audio quality
          Well, what are the actual source files for the audio? Sounds like you are using MP3 or embedded audio in compressed movie formats, which is pretty no-no when it comes to AE. Also, AE does only linear resampling and mixing, so you may inadvertently exceed levels here and there. You should by all means make sure your sources are clean to begin with, meaning they should be 44 kHz/ 48 kHz WAV files, properly normalised. Aside from that, you can always find audio mixing tools either as trial versions (Audition, Soundbooth, Cubase) or even free (Audacity), several of which allow you to import reference video files to achieve sync. Also consider VirtualDub and similar tools to fuse your audio mix with the video.
          Mylenium
          • 2. Re: PC Win XP AE 7- Bad audio quality
            Jonas Hummelstrand Level 2
            The versions prior to CS3 had some definite sound bugs that could cause pops (and worse) especially when using MP3s. Sound support in CS3 and CS4 is much better.
            - Jonas Hummelstrand
            http://generalspecialist.com/
            • 3. Re: PC Win XP AE 7- Bad audio quality
              Level 1
              Actually I'm using MP3 44.1 kHz. Thanks for advice, I will check if converting it should help.
              Edit: It really works! So the solution is to using WAV instead of MP3. Big thanks.
