0 Replies Latest reply on Aug 6, 2008 12:54 PM by stuehler.tech
    trouble playing one swf inside another
    stuehler.tech
      All,
      I'm trying to load a SWF and play it inside another SWF.
      Both SWFs are targeted to use Flash Player 8, and AS 2.0
      So, in the parent, I've got code that looks like this:
      var movie_mc:MovieClip = this.createEmptyMovieClip("movie_mc",
      this.getNextHighestDepth());
      var mcLoader:MovieClipLoader = new MovieClipLoader();
      mcLoader.addListener(this);
      mcLoader.loadClip("someothermovie.swf",movie_mc);
      function onLoadInit(target_mc:MovieClip):Void {
      target_mc.play();
      When I run this in the Flash IDE, it runs beautifully.
      However, when I try to play the movie in a browser, the inner movie
      plays for a few frames, then just stops playing.
      So potentially relevant facts -
      - Both movies are set to run at 30 FPS
      - The inner movie is about 2,700 frames long
      - The inner movie has an audio track embedded on one of the layers
      - The audio track has sync=Stream
      I'm definitely sure the inner movie has stopped playing - I set an
      interval in the parent movie that checks the inner movie's
      _currentframe, and displays it in a text field - sure enough - it gets
      to about frame 25, and just stops.
      Notably - if I remove the audio track from the inner swf, the entire
      thing runs perfectly, both in the Flash IDE and in a browser.
      So, i'm assuming the audio track embedded in a layer, and/or
      Sync=Stream has something to do with this?
      Any advice or insight is MUCH appreciated!
      Cheers,
      Matt
