1 Reply Latest reply on Jan 13, 2009 1:32 AM by Jon-M-Spear
    Precompose transparency in AE7 Pro
    Jon-M-Spear Level 4
      Help! I think I'm having a senior moment.
      I've created a comp in which one of the layers is a light beam created using the Ramp effect and a mask - the black end of the ramp correctly shows as transparent against a test background in the composition.
      HOWEVER... If I then pre-comp it (after removing the background), then insert it into my main comp, the transparency has gone and shows as black against the main comp's background.
      After doing more test, it looks as though Ramp does not retain transparency once pre-comp'd. Is there another technique I should be using?
      I'd appreciate any help. Thanks.
