3 Replies Latest reply on Feb 11, 2009 11:13 PM by Mylenium
    CS3 templates
    mbbrooks58
      Can anyone tell me where to locate templates? Are they in a folder? I have opened browse template projects in file menu, that opens in Bridge, but then I'm not sure where to find. I'm a new user of aftereffects. Thanks.
        • 1. Re: CS3 templates
          They should be in a sub-folder of your After Effects install directory, e.g. C:\Program Files\Adobe\After Effects CS3 on Windows. they could also be under C:\Program Files\Common Files\Adobe.
          Mylenium
          • 2. Re: CS3 templates
            mbbrooks58 Level 1
            Do you think it would be a folder called templates? I don't see any folder named that. I did a file extension search, couldn't find & now I'm wondering if it was installed (By our IT) it was missed. Thanks.
            • 3. Re: CS3 templates
              Yes, it should be a Templates folder or a sub-folder of Presets. It's quite possible it never got installed, so double-check. You could also simply run a normal Windows file search and see, if anything with an *.aet extension turns up somewhere. Those would be the project templates.
              Mylenium
