7 Replies Latest reply on Feb 17, 2009 3:38 PM by Navarro Parker
    3 gig max ram OS10.4 - CS3
    mr. ichybob Level 1
      I have 5 gigs of RAM, but in my memory prefs, "Maximum Memory Usage" won't show more than 3 gigs even if I put it above 100%. It tops out at 3 gigs, (it will show less however). I have "Render Multiple Frames Simultaneously" checked in "Multiprocessing". Is this normal behavior?
      Dual 2.5 G5, OS10.4, CS3
        • 1. Re: 3 gig max ram OS10.4 - CS3
          (Steve_Patterson) Level 1
          Yup. For the time being, that's an OSX limitation.
          It'd be great to unlock the full potential of the 64-bit OS and allocate more RAM per-process, but for now, that's the cap.
          • 2. Re: 3 gig max ram OS10.4 - CS3
            mr. ichybob Level 1
            darn, thanks for the reply.
            • 3. Re: 3 gig max ram OS10.4 - CS3
              Todd_Kopriva Level 8
              To be clear, the report of the RAM being used is for the foreground application. The background instances that are spawned when the Render Multiple Frames Simultaneously option is selected are not reported in that number. They can and will use all the RAM you can feed them (up to a maximum amount of 2-4GB).
              from "Memory usage and storage" page of After Effects Help:
              "The operating system imposes certain limits on the amount of memory that an application can use. After Effects on the Mac OS X operating system can use up to 3.5 GB of RAM, although only about 3 GB is actually available to the foreground application, because Mac OS X uses approximately 500 MB to load the user interface libraries. After Effects on 32-bit Windows operating systems can use up to 3 GB of RAM; however, to use more than 2 GB in After Effects, you must configure Windows XP or Windows Vista appropriately. After Effects on 64-bit Windows operating systems can use up to 4 GB of RAM with no special configuration.
              Note: These numbers are for each After Effects process. The background processes used to render multiple frames simultaneously can each use the amount of RAM mentioned above."
              • 4. Re: 3 gig max ram OS10.4 - CS3
                mr. ichybob Level 1
                thanks Todd, following your link to an additional page I found this
                "If background processes are used for rendering, then the main foreground application is not used for rendering. Therefore, creating background processes only adds to the total number of processes used for rendering if enough resources are available for at least two background processes to run."
                Which leads me to believe that on my Dual core G5 I will gain nothing by enabling multiprocessing (in CS3), Is that correct?
                • 5. Re: 3 gig max ram OS10.4 - CS3
                  Not necessarily. If you've given little RAM to the foreground application, then you may have enough for 2GB for each of two background processes. But then your RAM previews will be very short, since the foreground application's RAM is used to collect those frames.
                  Whether you'll benefit from enabling Render Multiple Frames Simultaneously depends on a lot of things, including the complexity/size of your composition. Give it a shot; do some tests.
                  FWIW, I don't use Render Multiple Frames Simultaneously on my personal two-core laptop until I'm rendering for final output. That's just what happens to make the most sense for my personal projects. But I almost always leave Render Multiple Frames Simultaneously on on the four-core machine that I use for work.
                  • 6. Re: 3 gig max ram OS10.4 - CS3
                    mr. ichybob Level 1
                    Thanks Todd, really appreciate getting answers to these questions.
                    • 7. Re: 3 gig max ram OS10.4 - CS3
                      Navarro Parker Level 3
                      On a Dual Chip? Probably not.
