7 Replies Latest reply on Feb 18, 2009 2:15 PM by alwinch
    new system suggestions for the techies
    alwinch Level 1
      Hi, I'd appreciate some advice on a new system. Am I overkilling or under.
      What I am doing. Mostly short form after effects projects for video, so not doing long form video or film effects.
      What I am lookng at system-wise
      1. Board- intel 5860 i7 or equilvilant
      2. Chip i7 920
      3. Ram -12 GB corsair ddr 3 1600 ram (too much?)
      4. Drives-3 500 GB 32 MB sata 2 perpendicular HD
      5. Card-Quatro FX3700 512
      6. Vista Business 64
      I realize the quatro CX is adobe recommendend and it is always better to be more powerful than not enough, but with California raising the proce of everything I will need something that will work in the refridgerator box I will be living in.
      Is there any of these areas that seem like overkill for the level of work I am doing? Anything too little?
      Thanks for your opinions.
        • 1. Re: new system suggestions for the techies
          craulmedia Level 1
          can't be overkill at any time, just the right hardware mix makes working AE flawlessly.
          if your mainboard can handle that amount of RAM, fine, may you will find the benefits when activating multiprocessoring in AE. There are some topics bout that.
          • 2. Re: new system suggestions for the techies
            Andrew Yoole MVP & Adobe Community Professional
            Get the fastest CPU you can afford. The more cores the better, if you plan to use multiprocessing.
            Get minimum 2GB of RAM for each core of your processor, plus an additional 2GB. So if you have 4 cores, the minimum RAM you should get is 4 x 2 + 2 = 10GB. But more is better still, so 12GB is not too much, no.
            You'd get better HDD value with 1TB drives these days, or even 1.5TB. I bought a 1.5TB Seagate drive for US$140 last week. You can never have too much drive space.
            Don't spend too much on your video card, if AE is your only 3D/OpenGL application. AE's OpenGL capabilities are fairly standard, so any mid-level display card should cope with it's requirements.
            • 3. Re: new system suggestions for the techies
              Navarro Parker Level 3
              Yeah, to back up what Andrew said. Even a $100 current gen graphics card is more than enough for anything AE needs.
              I highly recommend a RAID if you have a multicore system. I've found that with 8-cores, each one wants to access and write a frame of footage off your drive at the same time. So if you have 1080p source files, that's nearly 50MB reading and 50MB writing. That's a lot of disk activity.
              • 4. Re: new system suggestions for the techies
                alwinch Level 1
                Thanks for your reponses. The Graphics card has me stumped then. What I am being told, and I take it with a grain of salt since they are trying to make a living,is that CS4 works much better with the Quadro cards and they are anywhere from 500 to 2OOO. Are they thinking Premiere and HD editing needing that type of graphics card processing power and 3D or CAD programs rather than AE? Hope so, dave me bundle on the card.
                • 5. Re: new system suggestions for the techies
                  For those kind of dollars, I'd be much more inclined to buy a more moderate display card, and a true HD I/O card like a Blackmagic Decklink or AJA. Then you can have true HD monitoring separate to your workspace.
                  http://www.decklink.com/products/
                  http://www.aja.com/html/products_windows.html
                  If you are working in HD, I second Navarro's RAID recommendation - drive speed is really stretched with true HD content.
                  • 6. Re: new system suggestions for the techies
                    >anywhere from 500 to 2000. Are they thinking Premiere and HD editing
                    Not per se. Even amongst the various Quadro types there are some that are causing problems. Compatibility and performance is dictated by the actual chipset on the card in combination with what driver version works best. It's really a lot more complicated. However, I agree with the previous posters - go for a normal GeForce. What cards like a GTX 260 or GTX 290 offer, is already way beyond what AE will ever use and, barring the aforementioned driver and config issues, should keep you happy for a while. And to echo another opinion: Get the fastest processor. Opt for an Core 7i 965 Extreme, if you have the budget, especially since it may become considerably cheaper in a month or so, when intel bring out the next stepping/ revision of their Core7i processors.
                    Mylenium
                    • 7. Re: new system suggestions for the techies
                      alwinch Level 1
                      Thanks for all the info. It is really helpful. As I look at the i7 chips, what kind of improvement can I really expect between the lower and the extreme? Will the time saving really justify the expense difference? If I used AE 10 hours a day a 10% differnce would be substantial. Only using it a few hours a day then the difernce might not be justified. Hard to translate the benchmatk test with real world improvements and get beyond the advertising hype. If anyone knows when the next chip might be coming out it would be worth waiting for the price drop. Damn California economy!
