8 Replies Latest reply on Nov 30, 2008 3:18 AM by Newsgroup_User
    synchronizing local and remote sites
    troika22 Level 1
      Greetings
      I created a site locally and then FTPed it up to a server at my ISP. The site was working fine until I made a number of changes that I note below. When in DW and I try try to preview in a browser, I am unable to view any of the files in any browser because DW is unable to locate the files locally and remotely.
      The error message I get is:
      Firefox can't find the file at /______/______/_____/_____/ThankYouVeryMuch/Website/tyvmi 3/index.htm.
      The changes that were made to the site:
      - I reorganized my folders locally thereby creating a new root folder. When I tried to add 3 pages, I received several error messages. One of them was that DW was unable to locate the home page. Another was that it was unable to create the site map and if I'm not mistaken DW was unable to create cache files.
      - My client had a friend add some Google analytics to the site. This person also created an XML site map. Obviously, the local and web sites were not synchronized so I was receiving more error messages.
      - I then downloaded the site to a new directory in the new root folder I created above. This downloaded site is my local root directory in the Site manager and is located at ./______/______/_____/_____/ThankYouVeryMuch/Website/tyvmi 3/index.htm
      - These are my current directories for the site thankyouverymuchinc.com:
      Site name: Thank You Very Much Inc
      Local: ThankYouVeryMuch
      ----------> Website
      -------------> tyvmi 3
      ---------------> index.htm
      ---------------> pages
      Remote: host: ip address
      ----------> www/htdocs/
      Many thanks
      Marlene
        • 1. Re: synchronizing local and remote sites
          Level 7
          Do you have a testing server defined?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "troika22" <webforumsuser@macromedia.com> wrote in message
          news:ggsec9$obo$1@forums.macromedia.com...
          > Greetings
          > site
          > in DW
          > files in
          > When I
          > that
          > create
          > person
          > ----------> Website
          > Many thanks
          > Marlene
          • 2. Re: synchronizing local and remote sites
            troika22 Level 1
            No I do not have a testing server defined.
            • 3. Re: synchronizing local and remote sites
              Level 7
              Are you sure?
              What is the path to your local root folder? And what do you see in the
              address field of the browser when you try to preview and get the file not
              found error?
              Are you using Frames, by any chance?
              news:ggsgbq$qld$1@forums.macromedia.com...
              • 4. Re: synchronizing local and remote sites
                troika22 Level 1
                Hello
                I'm fairly certain i do not have a testing server defined. When I go into Manage Site/Testing Server, I have none selected for server model and access.
                I am not using frames on the site, thankyouverymuchinc.com.
                The path to my local root folder is:
                Macintosh OSX/Documents/• Projects/Clients/ThankYouVeryMuch/Website/tyvm 3/index.htm
                The address field of the browser when i try to view it and get the file not found error is:
                file:///Macintosh%20OSX/Documents/%C2%A5%20Projects/Clients/ThankYouVeryMuch/Website/tyvmi %203/index.htm
                Marlene
                • 5. Re: synchronizing local and remote sites
                  Level 7
                  Is there really a question mark in the folder name?
                  Macintosh OSX/Documents/? Projects
                  That's a potential problem. Can you rename that folder?
                  news:ggsk5p$1lt$1@forums.macromedia.com...
                  > Hello
                  > access.
                  > Macintosh OSX/Documents/? Projects/Clients/ThankYouVeryMuch/Website/tyvm
                  > 3/index.htm
                  > not
                  > found error is:
                  > site/tyvmi%203/index.htm
                  > Marlene
                  • 6. Re: synchronizing local and remote sites
                    troika22 Level 1
                    Hello
                    I renamed the directory to projects. It was originally • Projects.
                    I received the following error messages repeatedly when I set the local set and image info to this newly named directory:
                    WARNING: The selected folder does not contain the current site's home page. The site cannot be built.
                    The cache will now be recreated because the name, root folder, HTTP address, or cloaking settings of the site have been changed.
                    The good news is that I can now preview my pages through DW in a browser.
                    How might I remedy this warning message regarding the home page. The home page is in the directory I set in the site manager.
                    Marlene
                    • 7. Re: synchronizing local and remote sites
                      Level 7
                      Open this site definition for editing.
                      click the Advanced tab to do this quicker.
                      in the SiteMap section, change the location of this site's "homepage"
                      It will have the old info with the ? in the folder name.
                      Also double check the Local Info section->Default Images folder location if
                      you filled that out earlier.
                      Alan
                      Adobe Community Expert, dreamweaver
                      http://www.adobe.com/communities/experts/
                      • 8. Re: synchronizing local and remote sites
                        Level 7
                        Or right click on the file that is the home page in DW's FILES panel, and
                        elect to set it as the home page.
                        "Alan" <please_dont_mail_me@example.com> wrote in message
                        news:C5575614.3174CD%please_dont_mail_me@example.com...
                        >> page.
                        > if
                        > Alan
