1 Reply Latest reply on Mar 1, 2009 2:39 PM by Andrew Yoole
    After Effects Apprentice
    k.loy Level 1
      Hi
      I am new to learning After Effects, but have t good knowledge of Flash so I am familiar with the basic principles of motions graphics.
      I am going through the book After Effects Apprentice.
      I noticed that when I try to RAM Preview of the projects, some of them stop at 12 secoonds. I see the little green bar at the top stop at 12, when it should go to 30. It doesn't say anything about this in the book.
      Though the entire 30 second movie will render fine.
      I have a new MacBook.
      What's going on?
        • 1. Re: After Effects Apprentice
          Andrew Yoole MVP & Adobe Community Professional
          I've cut and paste this answer by Todd Kopriva directly from another thread on the same topic:
          RAM preview will only preview the number of frames that can fit into RAM---hence the name. The advantage is that the frames can be played back at (or near) real-time speed from RAM. If you want to preview more frames than can fit into RAM but sacrifice the speed of playback, use standard (spacebar) preview.
          All of this is explained in detail in the "Preview video and audio" section of After Effects Help.
          If you're just getting started with After Effects, I strongly recommend that you go through the materials linked to from the After Effects Help and Support page, especially in the "Getting started" section.
