3 Replies Latest reply on Mar 11, 2009 2:28 PM by fredou_79
    CRASH on STARTUP screen
    fredou_79 Level 1
      I cannot open AE (7.0 and CS3) it crashes on startup screen.
      I tried checking the fonts, clearing preferences with CTRL+ALT+SHIFT, didn't work.
      It's a fresh install on a freshly formated and newly installed OS.
      Sometimes it openend but sometimes it didn't, but now it never opens.
      My computer specs:
      Windows Vista x64 (fresh install + fresh format on C drive)
      and optimized for memory
      AspectHD v5.4 last build
      AMD Athlon x2 6400+
      M2N-SLI Deluxe
      8 GB RAM 800Mhz ECC enabled
      Cool & Quiet Enabled
      NVIDIA Quadro FX 1500
      Creative X-FI XTREME music
      C drive 500GB
      RAID 0 drive 2x250 GB
      RAID 0 drive 3x320 GB
      Dual Monitor setup with Ultramon 3
      O&O Defragmented all drive
      O&O Clevercache managing memory
      All drivers are up-to-date.
      I've heard of deinstlling updates and reinstalling them, how would I do that, is this a possible sollution?
      I cannot works on my system which I newly reseted and upgraded to be able to work more smoothly :(
        • 1. Re: CRASH on STARTUP screen
          Note, that AE7 is not officially supported on Vista, so you are on your own mostly. Try turning off UAC, DEP and also run as administrator/ with administrative privileges. For CS3, please remove the OpenGL plug-in (C:\Program Files (x86)\Adobe\After Effects CS3\Support Files\Plug-Ins\Extensions\AE_OpenGL.aex. Of course the same tips that apply to AE7 should be tried first as well. Other than that - could also be a problem with the Cineform CoDec. They are pretty sensitive, to say the least.
          Mylenium
          • 2. Re: CRASH on STARTUP screen
            fredou_79 Level 1
            Problem signature:
            Problem Event Name: APPCRASH
            Application Name: AfterFX.exe
            Application Version: 7.0.128.244
            Application Timestamp: 437bbc89
            Fault Module Name: CFHD.DLL_unloaded
            Fault Module Version: 0.0.0.0
            Fault Module Timestamp: 4935d824
            Exception Code: c0000005
            Exception Offset: 09c023f0
            OS Version: 6.0.6001.2.1.0.256.1
            Locale ID: 4105
            Additional Information 1: fd00
            Additional Information 2: ea6f5fe8924aaa756324d57f87834160
            Additional Information 3: fd00
            Additional Information 4: ea6f5fe8924aaa756324d57f87834160
            • 3. Re: CRASH on STARTUP screen
              fredou_79 Level 1
              Looks like cineform is causing problem according to this line:
              Fault Module Name: CFHD.DLL_unloaded ?
