1 Reply Latest reply on Mar 23, 2009 2:45 PM by Andrew Yoole
    RAM question
      Hi all,
      Just wondering if there is a maximum amount of RAM after effects can handle? as far as i know after effects uses a2gb of ram for every core, is this accurate?
      thanks for reading :-)
        • 1. Re: RAM question
          Andrew Yoole MVP & Adobe Community Professional
          It depends on what operating system you use, which you haven't mentioned.
          Generally speaking, a minimum of 2GB per core is the optimal way to configure your machine. If you're using WinXP 32, any more than a total 4GB of RAM in the machine will be wasted.
