3 Replies Latest reply on Feb 14, 2008 11:13 AM by David Wigforss-Hv1BNN
    loop video clip?
      I want to import short video clips and loop them continously within a composition.
      Is there an automated way to repeat the clip as a loop without manually stacking layers of copied instances?
      I have AE V7 pro
      thanks,
      mike
        • 1. Re: loop video clip?
          Andrew Yoole MVP & Adobe Community Professional
          There is a loop feature in the Interpret Footage dialog box.
          You can also use expressions to loop a clip. Read about Loop Expressions in the AE CS3 Live Docs:
          http://livedocs.adobe.com/en_US/AfterEffects/8.0/help.html?content=WS3878526689cb91655866c 1103906c6dea-79f8.html
          • 2. Re: loop video clip?
            Todd_Kopriva Level 8
            Here's some more detail about the loop feature in the Interpret Footage dialog box that Andrew mentioned:
            1. In the Project panel, select the footage item to loop.
            2. Choose File > Interpret Footage > Main.
            3. Type an integer value for Loop and click OK.
            • 3. Re: loop video clip?
              David Wigforss-Hv1BNN Level 2
              Or you can use Time Remap, set a key on the frame before the loop (set it to HOLD). Delete the keyframe at the end of the layer. Copy the first keyframe where you want the loop to occur. Copy them all, and keep pasting them throughout the timeline..
