This content has been marked as final.
Show 3 replies
1. Re: Titling Best Practices
(plumeragent) Feb 17, 2008 3:05 PM (in response to DawnTreader777)What I've gathered and been taught regarding titling font choices is not to use serifed fonts, but use only sans serif. I like Gill Sans.
Also, you generally don't want to use fonts with very narrow shape elements such as the ascenders and descenders, since those areas will display the same jaggyness as serifs do in video, but that also depends on the size of the titles you're creating, whether they are scrolling titles as in the end credits crawl, or are the opening credits where the credit titles are generally large and appear one at a time. The larger they are the less chance of jaggies showing, especially with vector-based fonts (postscript), in the final output to video.
I've had great results laying out the titles in Illustrator, then bringing them into the AE project via the Illustrator file. Anti-aliasing (or lack of it) and pixel shape may also be a cause, but I'm not sure about that.
Others here will hopefully elaborate or disagree. -
2. Re: Titling Best Practices
Todd_Kopriva Feb 18, 2008 9:11 AM (in response to DawnTreader777)Have you read the "Best practices for creating text and vector graphics for video" section of After Effects CS3 Help on the Web?
If you don't feel like clicking, here's the body of that document:
"Text that looks good on your computer screen as you are creating it can sometimes look bad when viewed in a final output movie. These differences can arise from the device used to view the movie or from the compression scheme used to encode the movie. The same is true for other vector graphics, such as shapes in shape layers. Keep the following in mind as you create and animate text and vector graphics for video:
* You should always preview your movie on the same sort of device that your audience will use to view it, such as an NTSC video monitor. (See Preview on an external video monitor.)
* Avoid sharp color transitions, especially from one highly saturated color to its complementary color. Sharp color transitions are difficult for many compression schemessuch as those used by MPEG and JPEG standardsto encode. This can cause visual noise near sharp transitions. For analog television, the same sharp transitions can cause spikes outside the allowed range for the signal, also causing noise.
* When text will be over moving images, make sure that the text has a contrasting border (such as a glow or a stroke) so that the text is still readable when something the same color as the fill passes behind the text.
* Avoid thin horizontal elements, which can vanish from the frame if they happen to be on an even scan line during an odd field, or vice versa. The height of the horizontal bar in a capital H, for example, should be three pixels or greater. You can thicken horizontal elements by increasing font size, using a bold (or faux bold) style, or applying a stroke. (See Formatting characters.)
* When animating text to move verticallyfor scrolling credits, for examplemove the text vertically at a rate in pixels per second that is an even multiple of the field rate for the interlaced video format. This prevents a kind of twitter that can come from the text movement being out of phase with the scan lines. For NTSC, good values include 0, 119.88, and 239.76 pixels per second; for PAL, good values include 0, 100, and 200 pixels per second.
Apply the Autoscroll - Vertical animation preset in the Behaviors category to quickly create a vertical text crawl.
Fortunately, many problems with text in video and compressed movie formats can be solved with one simple technique: Apply Fast Blur to the text layer, with a Blurriness setting between 1 and 2. A slight blur can soften color transitions and cause thin horizontal elements to expand." -
3. Re: Titling Best Practices
DawnTreader777 Feb 18, 2008 5:17 PM (in response to DawnTreader777)That's all great advice. thanks for pointing it out.
so what about interlacing and de-interlacing and progressive scans? how does that affect text?
