1 Reply Latest reply on Feb 18, 2008 8:11 AM by A. Cobb
    Rendering
      when i start rendering in Adobe AE CS3 only 5 seconds render is output, not more than that, what will be the solution.. output file is Best quality DV Pal.
        • 1. Re: Rendering
          A. Cobb Level 3
          Is your render set to Work Area Only, or Length of Comp? If the former, there are two possible solutions: either set the render to Length of Comp to render the whole comp regardless of the work area, or set the comp's work area to the length you want rendered.
