1 Reply Latest reply on Sep 10, 2008 4:32 PM by Newsgroup_User
    Pretty straightforward AJAX question
    Level 7
      I'm looking to have a 3-option menu populate a nearby div with external
      content (from 3 external files).
      How do I do this with the least code possible? I've googled it, but the
      results that turn up all use different JS to do it, and all seem to do more
      than just load the content.
        • 1. Re: Pretty straightforward AJAX question
          Level 7
          Mike,
          This is basically what Spry Tabbed Panels is doing. All you'll need to
          do is to rearrange your markup so that the "tabs" look like a "menu".
          The easy way to get the external content into the panels is use SSIs. If
          you want to get fancy, then you can try setting up a Spry data set to
          asynchronously load the data to the div as it is displayed.
          HTH,
          Randy
