1 Reply Latest reply on Apr 14, 2008 10:15 AM by Mylenium
    After Effects AEGP Plugin Media IO Plugin Error
    Level 1
      My artist is getting the following message in After Effects CS3. I don't have any more details at the moment.
      Error message:
      Encoding Failed. MediaIO2 error: 0x40050012
      (5027::12)
      Product: After Effects CS3.
      O/S: Windows XP SP2.
      Computer: HP xw8200 w/ 4GP ram.
      no printer.
      Any ideas?
        • 1. Re: After Effects AEGP Plugin Media IO Plugin Error
          Well, hard to tell without further info, but if you are trying to render to MPEG-II(DVD) or some such thing, then most likely the comp sizes are incorrect. The Adobe Media Encoder strictly adheres to the specs and will only render comps that use the pre-defined resolutions (NTSC DV/ NTSC Widescrren, PAL DV, PAL Widescreen). Everything else will cause a failure. Simialrly, rendering stuff for other target outputs is bound by the same rules.
          Mylenium
