11 Replies Latest reply on Jul 31, 2008 3:20 PM by Lazlo Hollyfeld
    Rename Layer!! Impossible!
      Hello, i try to rename any layer or folder or anything by pressing "Enter"!
      I also saw videos people doint that with Enter!But if I press enter it effekts as double mouse click!!! So if i press enter on a layer it opens the footage, if i press enter on a folder it opens a folder!!
      I tryed to edit shortcuts but i cant open that shortcuts windows, i also cant open help file (F1)...
      Can you help me ? Thx a lot
        • 1. Re: Rename Layer!! Impossible!
          Andrew Yoole MVP & Adobe Community Professional
          Press return, not Enter.
          • 2. Re: Rename Layer!! Impossible!
            Level 1
            So then it gets DELETED....*confused*...
            • 3. Re: Rename Layer!! Impossible!
              Todd_Kopriva Level 8
              Are you using a Mac?
              From the "View or change layer information" section of After Effects Help on the Web:
              "To rename a layer or property group, select it in the Timeline panel and press Enter on the main keyboard (Windows) or Return (Mac OS)."
              That's odd, and clearly the sign of a problem, but you shouldn't be using the Help document installed on your hard disk, anyway. As long as you've got an Internet connection, use After Effects Help on the Web (LiveDocs): http://livedocs.adobe.com/en_US/AfterEffects/8.0 . When you don't have a connection, use the PDF version, which you can download from here: http://www.adobe.com/go/documentation . The PDF version is updated as often as the LiveDocs version. The version of Help that you get when you press F1 is out of date, has many errors, and does not include the hundreds of links to tutorials and other resource that are in the other versions.
              • 4. Re: Rename Layer!! Impossible!
                Level 1
                i am using Windows Vista Ultimate with Adobe After effects CS3 Pro (Trial)
                should i reinstall it?? ...i so confused about this, all shortcuts work but not this one...mhhh
                • 5. Re: Rename Layer!! Impossible!
                  I would only assume this to happen you were using a notebook with some custom keyboard manager tool. If it happens on your normal desktop, it's probably an issue with your language settings. Which language settings do you use for sour OS? Russian? Georgian? English? Do you launch AE in English?
                  Mylenium
                  • 6. Re: Rename Layer!! Impossible!
                    Level 1
                    I use Russian unicode, my Windows (ultimate) is English 32bit, my AFX cs3 pro is English, my keyboard settings set to "EN" English, i tryed other languages , nothing... I have nootebook from fujitsu siemens ..
                    i reinstalled the hole AFX same thing, if i press Enter its same as doubleclicking the item, i dont get any Help by pressing F1 also cant open Shortcuts window...what the hell...
                    thats not the first time a have adobe after effects problems...
                    the best way to solve such problems is too look at my Desktop with TeamViewer
                    • 7. Re: Rename Layer!! Impossible!
                      It's certainly a configuration matter with the notebook keyboard. Did you check the BIOS? Which model is it? Amilo? Esprimo? Lifebook? I know that there are certain extension packs for some of the product series, my boss went crazy over enabling some functions on his tablet notebook a while ago which all hinged on installing a special driver pack... If you can give the exact name and year of production, I could look it up and maybe I can find out what's going on.
                      Mylenium
                      • 8. Re: Rename Layer!! Impossible!
                        Level 1
                        Please need help...i cant give layers names...is there any other way to di this except of pressing "ENTER" or "RETURN"...?
                        Thx a lot
                        • 9. Re: Rename Layer!! Impossible!
                          Kiril, please, you need to provide more information. Nobody will be able to help you if you don't cooperate. we are all willing to go to some lengths to resolve the matter, but neither of us has any telepathic power. With notebooks anything is possible due to keyboard remapping, so unless we know something more about it, there's no way of resolving the matter. You may temporarily be able to define a new hotkey for renaming, so open your shortcut prefs file (Documents and Settings/Kiril/Application Data/Adobe/After Effects/8.0/Adobe After Effects 8.0 Shortcuts.txt) and find this section:
                          ["COutline"]
                          "Clear" = "(Delete)(FwdDel)"
                          "Rename" = "(Return)"
                          Change it to something like
                          ["COutline"]
                          "Rename" = "(F1)"
                          But don't forget to unassign it:
                          "HelpAfterEffectsHelp" = "(F1)"
                          must be changed to
                          "HelpAfterEffectsHelp" = "()"
                          Mylenium
                          • 10. Re: Rename Layer!! Impossible!
                            Level 1
                            Well thanks a lot !!! That did the trick =]
                            I dont know why my half of after effects dont work,
                            i hope dxdiag can help a little bit...
                            System Information
                            Time of this report: 5/16/2008, 09:50:47
                            Machine name: DIMAIRA
                            Operating System: Windows Vista Ultimate (6.0, Build 6001) Service Pack 1 (6001.longhorn_rtm.080118-1840)
                            Language: English (Regional Setting: German)
                            System Manufacturer: FUJITSU SIEMENS
                            System Model: AMILO Xa 2528
                            BIOS: Version 1.0
                            Processor: AMD Turion(tm) 64 X2 Mobile Technology TL-56 (2 CPUs), ~1.8GHz
                            Memory: 2046MB RAM
                            Page File: 1005MB used, 3323MB available
                            Windows Dir: C:\Windows
                            DirectX Version: DirectX 10
                            DX Setup Parameters: Not found
                            DxDiag Version: 6.00.6001.18000 32bit Unicode
                            DxDiag Notes
                            Display Tab 1: No problems found.
                            Sound Tab 1: No problems found.
                            Sound Tab 2: No problems found.
                            Input Tab: No problems found.
                            DirectX Debug Levels
                            Direct3D: 0/4 (retail)
                            DirectDraw: 0/4 (retail)
                            DirectInput: 0/5 (retail)
                            DirectMusic: 0/5 (retail)
                            DirectPlay: 0/9 (retail)
                            DirectSound: 0/5 (retail)
                            DirectShow: 0/6 (retail)
                            Display Devices
                            Card name: NVIDIA GeForce 8600M GS
                            Manufacturer: NVIDIA
                            Chip type: GeForce 8600M GS
                            DAC type: Integrated RAMDAC
                            Device Key: Enum\PCI\VEN_10DE&DEV_0425&SUBSYS_110C1734&REV_A1
                            Display Memory: 1008 MB
                            Dedicated Memory: 241 MB
                            Shared Memory: 767 MB
                            Current Mode: 1440 x 900 (32 bit) (59Hz)
                            Monitor: Generic PnP Monitor
                            Driver Name: nvd3dum.dll,nvwgf2um.dll
                            Driver Version: 7.15.0011.5615 (English)
                            DDI Version: 10
                            Driver Attributes: Final Retail
                            Driver Date/Size: 7/19/2007 01:31:00, 5025792 bytes
                            WHQL Logo'd: Yes
                            WHQL Date Stamp:
                            Device Identifier: {D7B71E3E-4765-11CF-6B61-073101C2CA35}
                            Vendor ID: 0x10DE
                            Device ID: 0x0425
                            SubSys ID: 0x110C1734
                            Revision ID: 0x00A1
                            Revision ID: 0x00A1
                            Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
                            Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                            {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S34
                            • 11. Re: Rename Layer!! Impossible!
                              Lazlo Hollyfeld Level 1
                              Is there a way to reassign shortcuts in Mac versions of AE as you suggested?
