1 Reply Latest reply on May 9, 2008 5:30 AM by A. Cobb
    Particular
      with trapcode 3d stroke you are able to clip front and back when you are moving the stroke around objects. I am trying to accomplish the same thing with particular, but am having trouble doing that...any suggestions? I have a motion path set up to move the particles around an object, but alas, particular works within its own 3d space...yet I see no clip front or back camera options....
      Thanks!
        • 1. Re: Particular
          A. Cobb Level 3
          Look in the Visibility property group. There are near and far falloff options, the ability to assign a Z-buffer (if you using objects rendered out of a 3D program) and even the option to set a 3d layer as an obscuration layer. Particular will not render particles that fall behind the layer.
