5 Replies Latest reply on Nov 30, 2008 6:27 AM by Newsgroup_User
    Sorting with comboBoxes
      How can I get a combobox to sort different columns of a datagrid?
      For instance the first item in the combobox would sort the first column in the datagrid and the second item would sort the second column and so on.
      Dave
        • 1. Re: Sorting with comboBoxes
          Level 7
          "dmschenk" <webforumsuser@macromedia.com> wrote in message
          news:ggmg5o$ceg$1@forums.macromedia.com...
          > the
          This might point you in the right direction
          http://www.cflex.net/showFileDetails.cfm?ObjectID=415
          • 2. Re: Sorting with comboBoxes
            Thanks for your reply. Unfortunately I'm not try trying to filter the data in the columns, I just want to sort it.
            In the example in the original post which is derived from from http://blog.flexexamples.com/2008/04/09/creating-a-custom-sort-on-a-datagrid-control-in-fl ex/ .. the buttons do what I am trying to achieve .... my quest is to get the combobox to do same thing as the buttons.
            My guess is that the combobox items need to be bound withe the sortNew and sortOld functions but I've been trying for days now without any luck.
            Dave
            • 3. Re: Sorting with comboBoxes
              Level 7
              news:ggp25g$j39$1@forums.macromedia.com...
              > data in
              > trol-in-flex/ .. the buttons do what I am trying to achieve .... my quest
              > is to
              Try something like this:
              private function cbCloseHandler(event:Event):void {
              myLabel.text = "You selected: " +
              ComboBox(event.target).selectedItem.label;
              myData.text = "Data: " +
              ComboBox(event.target).selectedItem.data;
              switch (ComboBox(event.target).selectedItem.label) {
              case 'old':
              sortOld();
              break;
              case 'new'"
              sortNew();
              HTH;
              Amy
              • 4. Sorting with comboBoxes
                Thanks Amy
                That was the ticket!!
                case 'Old':
                sortOld();
                break;
                case 'New'"
                sortNew();
                Dave
                • 5. Re: Sorting with comboBoxes
                  Level 7
                  news:ggsqhr$8lc$1@forums.macromedia.com...
                  > Thanks Amy
                  You're welcome :-)
