1 Reply Latest reply on May 27, 2008 3:24 AM by Mylenium
    Render to m2v from AE
      I seem to have lost my ability to render my comp to m2v format for DVD straight from AE CS3. I recently did a hard drive wipe and reload, and may have failed to install all of the plugins I used to have. I have Mainconcept MPEG Pro HD3.1 and it is installed and working fine with PPro CS3. I also have Nucleo Pro installed and all seems well there.
      If anyone could please sugest what plug-in allows AE CS3 to render the comp to the MPEG-2 DVD format directly, I would appreciate it. Prior to my hard drive reload, I was able to do it and avoid an extra generation of rendering.
      Using WinXP Pro.
      Thanks!
      Ed
        • 1. Re: Render to m2v from AE
          Should not require any additional steps, but it seems the plugin for Premiere has disabled or "stolen" the references for MPEG-II output 'cos it treats the AE component as an older version of itself... Getting rid of the plugin and re-installing everything in a different order might fix the issue.
          Mylenium
