4 Replies Latest reply on Jun 17, 2008 10:48 AM by A. Cobb
    Particular Motion blur
    Navarro Parker Level 3
      With the advent of CS3's new adjustable motion blur sampling, is it still better use use Particular's built-in Sub-Frame Sampling Motion Blur or use Comp Settings?
        • 1. Re: Particular Motion blur
          A. Cobb Level 3
          I think Comp Settings will always give you a linear motion blur, whereas subframe sampling will run the simulation at finer granularity to generate the new samples.
          Edit: Looking at the Particular options, Comp Settings and Subframe Sample aren't mutually exclusive. And it doesn't look like the Subframe Sample reads the comp's sample settings , just the shutter angle/phase. So, use the same calculus you used prior to AE CS3 to determine which method works for you.
          What's more, I doubt there'd be any way for Particular to take advantage of adaptive sampling anyway, since the layer it's applied to isn't 3D and isn't moving, so it wouldn't have an adaptive sample rate.
          • 2. Re: Particular Motion blur
            Aaron is right. Particular does use its own routines for motionblur sampling since this stuff is not rooted in the AE SDK and developers have to take care of it themselves. Any enhancements in AE itself therefore go unnoticed. You will have to manually ramp up the number of samples if you need to go beyond 16 "steps", which is the old default for AE up to version 7 and will be used this way if you use "Comp Settings".
            Mylenium
            • 3. Re: Particular Motion blur
              Thanks for such a quick response!
              • 4. Re: Particular Motion blur
                A. Cobb Level 3
                Correction to my above comment: it's 2D layers, not 3D layers that use adaptive motion blur.
