1 Reply Latest reply on Jun 21, 2008 6:57 AM by Mylenium
    AF7 will not run installation
      When I attempt to lunch the Installer application to install AF7 it simply crashes. The disk seems fine and I installed it on the same computer once before (a Mac OS 10.4). I reinstalled the Design Premium Suite with no difficulties so I don't think there is anything wrong with the Installer.
        • 1. Re: AF7 will not run installation
          Well, maybe you should have installed in reverse order. Installing CS3 products before older versions surely must have some odd side effects, even on a MAc. Did you use the CS3 clean scripts before re-installing everything? Also make sure to clean out all OSX caches for fonts, application pre-fetch and so on. It's possible some odd data still lingers. Tools like OnyX can do this for you with a graphical UI.
          Mylenium
