4 Replies Latest reply on Dec 16, 2008 11:26 AM by mrmojarro
    HELP! Embedding Flash with Dreamweaver CS4
    chilversj
      Hello i'm have issues with CS4 embedding Flash FLV's.
      It won't show up when it's on the server but it's working locally.
      i've uploaded all the files in the scripts folder and the swf skin files.
      But it still won't work server-side.
      I did not have this issue with dreamweaver CS3 as i've found that Dreameaver CS4 seems to
      change how the code of how the .FLV is embedded
      any ideas??
      or is anyone else having this issue?
      thanks
      Jordan
      here's is my current test page link with a sample flv video:
      http://www.lambethdesktop.com/flashtest/index.html
      i've also attached the code of the html page it has been embedded in.
        • 1. Re: HELP! Embedding Flash with Dreamweaver CS4
          Level 7
          This script appears to be missing (or uploaded to the wrong folder)
          http://www.lambethdesktop.com/Scripts/swfobject_modified.js
          "chilversj" <webforumsuser@macromedia.com> wrote in message
          news:ggjr79$1s$1@forums.macromedia.com...
          > Dreameaver
          > CS4 seems to
          > any ideas??
          > thanks
          > Jordan
          > <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
          > " http://www.w3.org/TR/html4/loose.dtd">
          > <html>
          > <head>
          > <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
          > <title>Untitled Document</title>
          > <script src="Scripts/swfobject_modified.js"
          > type="text/javascript"></script>
          > </head>
          > <body>
          > <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="320"
          > height="240" id="FLVPlayer">
          > <param name="movie" value="FLVPlayer_Progressive.swf" />
          > <param name="quality" value="high">
          > <param name="wmode" value="opaque">
          > <param name="scale" value="noscale">
          > <param name="salign" value="lt">
          > <param name="FlashVars"
          > value="&amp;MM_ComponentVersion=1&amp;skinName=Clear_Skin_1&amp;streamName=http:
          > //theharnessedge.com/fcys/FCYS08.28.08&amp;autoPlay=true&amp;autoRewind=false"
          > <param name="swfversion" value="8,0,0,0">
          > <!-- This param tag prompts users with Flash Player 6.0 r65 and higher
          > to
          > download the latest version of Flash Player. Delete it if you don?t want
          > users
          > to see the prompt. -->
          > <param name="expressinstall" value="Scripts/expressInstall.swf">
          > <!-- Next object tag is for non-IE browsers. So hide it from IE using
          > IECC.
          > <!--[if !IE]>-->
          > <object type="application/x-shockwave-flash"
          > data="FLVPlayer_Progressive.swf" width="320" height="240">
          > <!--<![endif]-->
          > <!-- The browser displays the following alternative content for users
          > with
          > Flash Player 6.0 and older. -->
          > <div>
          > <h4>Content on this page requires a newer version of Adobe Flash
          > Player.</h4>
          > <p><a href=" http://www.adobe.com/go/getflashplayer"><img
          > src=" http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif"
          > alt="Get Adobe Flash player" /></a></p>
          > </div>
          > <!--[if !IE]>-->
          > </object>
          > <!--<![endif]-->
          > </object>
          > <script type="text/javascript">
          > swfobject.registerObject("FLVPlayer");
          > </script>
          > </body>
          > </html>
          • 2. Re: HELP! Embedding Flash with Dreamweaver CS4
            chilversj Level 1
            I've upoaded the swfobject_modified.js script to
            but it still doesn't work :(
            • 3. Re: HELP! Embedding Flash with Dreamweaver CS4
              gobdav Level 1
              I found out that I had a "scripts" folder locally that I hadn't put on the server yet. Once I did that, everything worked fine. Hope that helps.
              • 4. Re: HELP! Embedding Flash with Dreamweaver CS4
                mrmojarro
                I have a similiar trouble, ie7 just visualizate one "flash movie"; in the declaration script:
                swfobject.registerObject("FlashID2");
                swfobject.registerObject("FlashID");
                </script>
                when the two flash movies is declarated, no one visualizated, but, when i comment one, another one is visualizated.
                then the problem is in the "swfobject_modified.js", but where and how.
                and the trouble is in the new adobe dreamweaver cs4;
                Ideas, please.
