2 Replies Latest reply on Jun 29, 2008 7:26 AM by David Wigforss-Hv1BNN
    end bend
    EH....? Level 1
      When using Stabilization, how do I make the Rotation and Position default the last frame of a composition?
        • 1. Re: end bend
          What do you mean? Tracking works in both directions, so there is no problem in defining you last frame as the start reference for tracking and moving backwards in time.
          Mylenium
          • 2. Re: end bend
            David Wigforss-Hv1BNN Level 2
            Not sure what you mean, Norman. If you wanted to adjust all your scale values so that the last frame was 100%, you could create a temp null, goto last frame, copy the transforms onto the null (ie if layer was 150% scale, set null to 150%), parent layer to null, change null scale to 100%, delete null. Voila, all scales are adjusted proportionally.
