2 Replies Latest reply on Jul 21, 2008 7:13 PM by (CloudZ)
    (Help) After Effect 7.0 error 5027 :: 12
      My After Effect can't render into mpeg2, it always return this error message even if it's just a one empty 30 second composition.
      After Effects: AEGP Plugin Media IO Plugin
      There is a mismatch between Output Module settings and Transcode Settings. Please verify your settings and try again.Property Data Invalid!
      MediaIO2 error: 0x400e0004
      Frame dimensions out of bounds
      (5027 :: 12)
      Someone please help me, what I must do so I can render normally
        • 1. Re: (Help) After Effect 7.0 error 5027 :: 12
          Huh? What are the comp settings? They must be 720x480 for NTSC or 720x576 for PAL with teh respective correct pixel aspect ratios. Also make sure to disable/enable audio as needed in bothe the main Output Module settings >>>and<<< the MPEG-II exporter (just in case this will be the next error that pops up.
          also see here: http://mylenium.de/ae_errors/ae_errors_50xx_formats.html
          • 2. Re: (Help) After Effect 7.0 error 5027 :: 12
            Level 1
            Mylenium, thanx for the advice. But I just realize that it must be 720x480 for NTSC. Coz usually I can render NTSC MPEG2 in any resolution without any trouble. I've tried to change the comp settings and it's worked. Thanks a lot Mylenium.
