6 Replies Latest reply on Aug 6, 2008 9:43 PM by Mylenium
    LightFactory just stops working?
    Navarro Parker Level 3
      Anyone else run into this? I'm using Light Factory.... everything behaves as normal. But then something happens and the flare just doesn't appear in the comp! The layer is on, the effect is on, the brightness and position are all fine. Turning GPU/unmult on and off have no effect. There should be a visible flare. But there isn't. If I apply a new Light Factory to the same layer, a flare appears. But the original is still invisible.
      Its like this specific effect just decides not to render. My only solution is to delete the original and recreate it with a new freshly applied Light Factory.
      Any ideas what the funk is going on?
