1 Reply Latest reply on Aug 13, 2008 11:33 PM by Mylenium
    Swf AE Project Crash Error workaround
      If you, like me are pulling your hair out because you crash AE whenever you open a saved project containing certain swfs I've found a workaround that seems to work pretty reliably.
      I want to tell you to start a new project and just import the offending project into that project. That almost works, but for me, it still crashes. Here's the workaround:
      Load in a swf by itself (ideally one of the same ones that are in the offending project) into a new, blank project. Create a Comp by dragging the swf onto the the little create comp icon on the bottom left of the project window. Scrub around a little. THEN... import the offending project. Voila? For me it works.
      Don't know why, but I was about to kill something when I couldn't open any of my projects or backups with these particular swfs.
      Hope this helps someone not kill something.
      -Forrest
        • 1. Re: Swf AE Project Crash Error workaround
          Thanks for providing the solution. On a technical level I think that the pertinent routines are simply not initializing correctly just by loading in a SWF. My guess is that not opening and playing the SWF does not create an isolated/ sandboxed memory area and then it crashes on successive loads because they all attempt to occupy the same memory. Certainly a bug somewhere...
          Mylenium
