This content has been marked as final.
Show 4 replies
1. Re: AE crashes when I export QT
Mylenium Aug 27, 2008 12:36 AM (in response to RSA 777)Well, what version of QT are you using? iTunes? Which CoDec? What are your comp settings? Windows XP, I take it? There's a number of possible combinations of settings that might cause crashes, like e.g. odd aspect ratios with MPEG-4 based formats, but without further info it's hard to track down anything.
Mylenium -
2. Re: AE crashes when I export QT
Jonas Hummelstrand Aug 27, 2008 3:46 AM (in response to RSA 777)If you're having problems with After Effects, here's a bunch of troubleshooting tips:
i http://generalspecialist.com/2007/02/troubleshooting-after-effects-7.asp
- Jonas Hummelstrand
http://generalspecialist.com/ -
3. Re: AE crashes when I export QT
RSA 777 Aug 27, 2008 5:53 PM (in response to RSA 777)Mylenium,
QT Pro, the latest update, 7 I believe. No itunes. Codec? I did not see an option to choose a codec, sorry. XP Pro. I will check the aspect ratios. Since I was using QT for a web application I did not think the ratio would matter. I will check. It happens with QT and mpeg4. Thanks for getting back to me. Sorry for the trouble.
Jonas
Thanks for the link. Just need something to get me started in the right direction. Flash files are working fine, but my Seminary needs flash and QT for their server. -
4. Re: AE crashes when I export QT
Mylenium Aug 28, 2008 1:39 AM (in response to RSA 777)You can set the specific output CoDec (compression type) under the "Options" button in the output module settings panel. However, since you say you didn't do that, it would default to Animation or Photo-JPEG - that is, if you have enabled "Enable encoding using legacy codecs" in your system's control panel for Quicktime ("Advanced" tab). Otherwise it will latch on to H.264, which might explain part of your problem. The default settings may be unsuitable and thus crash AE. Similarly, your MPEG-4 settings may be crooked and AE may not be able to correctly create the GOPs, so it crashes after the first few frames. I recommend you attempt another render and set the log options to "Plus per Frame Info". this should provide some more insights.
Mylenium
