13 Replies Latest reply on Sep 26, 2008 2:21 AM by Jonas Hummelstrand
    cant import anything
    Level 1
      i got adobe after effects cs3 and i tryed to import riot gear and every time i try it after effects crashes...
      even if i try to import music or a picture it always crashes....
      just want to know if anyone knows how to fix this
        • 1. Re: cant import anything
          This matter has been discussed a dozen times and from compatibility issues with Windows Vista to merely damaged preferences there's an infinite number of combinations that may cause the misbehavior. Please do a search on the forum first. That aside, getting good help requires qualified questions in the first place - things like "My car doesn't run!" are not going to get anywhere. The car's battery could be empty, it could have no gas, it could be damaged, if you get my meaning. Conversely, you need to provide more info about your computer and any related stuff that may potentially affect AE.
          Mylenium
          • 2. Re: cant import anything
            Level 1
            ok well the adobe forums is the worst kind of forum i have ever seen....i cant navigate anywhere cause its so bad i dont know were im going....
            also what u want me to say? all i know is i cant import anything...
            here is some more "info" about my laptop
            Manufacturer:
            Hewlett-Packard
            Processor:
            Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz (2 CPUs), ~1.8GHz
            Memory:
            2046MB RAM
            Hard Drive:
            237 GB
            Video Card:
            NVIDIA GeForce 8400M GS
            Monitor:
            Generic PnP Monitor
            Sound Card:
            Speakers (Realtek High Definition Audio)
            Speakers/Headphones:
            Keyboard:
            USB Root Hub
            Mouse:
            USB Root Hub
            Mouse Surface:
            Operating System:
            Windows Vista Home Premium (6.0, Build 6001) Service Pack 1 (6001.longhorn_rtm.080118-1840)
            Motherboard:
            Computer Case:
            • 3. Re: cant import anything
              Level 1
              oh here is a video i made showing it...
              i tryed using 3 different compatibility formats in the video...
              in order.
              XP
              Windows 98/me
              and vista what i have
              http://vimeo.com/1780014
              • 4. Re: cant import anything
                I wouldn't go that far, but I agree that there are forums out there that are more comfortable to use. ;-) Anyway, to the matter at hand: I would try to disable visual effects in Vista first. Even if it sounds brutal, using the classical Windows design might be a good starting point. The compatibility modes should not have any effect, so you can go without them. Another thing to definitely try is to delete the prefs (Users/Dylan/AppData/Adobe/After Effects/8.0/After Effects CS3 Prefs.txt, if I'm not mistaken (not on my Vista machine at the moment)). I would also, before attempting to import anything, clean out the media cache. You can do so via the Prefs or simply delete the folder in your User directory. It's possible, some remnants of older files are floating about and mess up things or the folder is extremely full. If the tips provided don't help, check back here.
                Mylenium
                • 5. Re: cant import anything
                  Jonas Hummelstrand Level 2
                  I've collected a bunch of thing to try:
                  i http://generalspecialist.com/2007/02/troubleshooting-after-effects-7.asp
                  Please report back if you got it solved or not.
                  - Jonas Hummelstrand
                  • 6. Re: cant import anything
                    Level 1
                    ok ill try some stuff out
                    • 7. Re: cant import anything
                      Level 1
                      changing the visual effects dident do anything and i cant find the media thing you were talking about
                      • 8. Re: cant import anything
                        Dylan,
                        How far did you get in my list of tips?
                        I'd bet you have a bunch of 3rd party codec packs installed. They are infamous for causing problems.
                        • 9. Re: cant import anything
                          Level 1
                          Jonas Hummelstrand, on that site i really dont see anything that has to do with importing problems.
                          • 10. Re: cant import anything
                            Almost every tip on that list deals with problems that can affect importing. I'd start by uninstalling all 3rd party codec packs.
                            • 11. Re: cant import anything
                              Level 1
                              what do you mean by 3rd party codec packs?
                              • 12. Re: cant import anything
                                K-Lite, FF Codec Pack and that kind of nonsense.
                                Mylenium
                                • 13. Re: cant import anything
                                  Dylan,
                                  All of us here are trying to help you for free, out of the goodness of our hearts, so it's frustrating to realize that you don't follow the advice you are given.
                                  In the post I've linked to twice, there's instructions on how to do this, easily found if you search the web page for "codec."
