5 Replies Latest reply on Jun 8, 2009 4:15 PM by Josh mehler
    NO AUDIO
    Level 1
      Importing MOV. Video is fine, no audio to edit to. Can anyone help?
        • 1. Re: NO AUDIO
          Level 1
          A likely problem is the audio is encoded in a codec which AE cannot work
          with. If you can play the file in QTPro, you can export it and transcode
          the audio to something more usable like a standard Wav.
          • 2. Re: NO AUDIO
            Level 1
            similar problem, only we extracted the audio from the .mov in iMovie, then exported that audio as a .wav.
            we then imported the .wav file into after effects, yet still we don't have audio alongside visuals. all preferences & audio options are set to "on". but we can only play the movie with no sound.
            i dont want to edit the sound, i just need it to work to - need to set an animation on top of the movie.
            (using after effects 6.5)
            • 3. Re: NO AUDIO
              Ko Maruyama User Group Manager
              Make sure your audio exists on channels 1&2
              • 4. Re: NO AUDIO
                Level 1
                Just checking- you're asking AE to initiate a preview with audio, correct? RAM preview (zero key on keypad) or audio preview (. on keypad). You won't get audio otherwise.
                • 5. Re: NO AUDIO
                  Josh mehler Level 1
                  Gah! This is it.  Stuip audio exporting from screen capture.  I exported the audio as AIFF and cha ching.  Made a pre-comp of the video and audio tracks together and that fixed it.
                  THANKS!
