0 Replies Latest reply on Dec 1, 2008 3:07 PM by brywilson88
    Inserting data into db
    brywilson88 Level 1
      Using dreamweaver, I set up an insert form with two dynamic lists in menu format. These menus allow the user to ONLY insert one item. I want to insert multipule items into a db table column that has the SET attribute.
      Can someone point me in the right direction to change the insert function to allow multipule items? Not sure where to start looking.
      Or, is there a way to dynamicly pull the set() creteria that I put in when I set up the column? I tried to use dreamweavers dynamic menu function to pull data from the table into my insert form - but it would not pull the information I used under the structure tab when I set up the set() column.
