24 Replies Latest reply on Feb 27, 2009 9:49 PM by Panoholic
    DNG Converter clips Pentax PEF images
      I wish to convert Pentax PEF files to DNG files due to the better compression and shell handling of the DNG format.
      I have tried converting using Adobe DNG Converter 5.2.0.65 As noted in http://www.adobeforums.com/webx/?14@@.3bc03c04.59b79390/46 the net result is that the image is clipped on the right and bottom edges - in my case, from 3888x2608 to 3880x2600.
      A reduction in the image dimensions is clearly not an accurate conversion. Is there a way to work around this problem, or to fix the underlying issue in the software?
