This content has been marked as final.
Show 3 replies
1. Re: Stream Requested does not Exist
Jeff Bellune Aug 23, 2007 4:57 PM (in response to Spoot51)No name calling. :)
Can you export from VOB2MPG as elementary streams (separate video and audio)?
Otherwise try extracting elementary streams using either VideoReDo or Womble MPEG Video Wizard . They aren't free, but their trial versions are very generous.
I suspect, in this case, that elementary streams may work better for you. -
2. Re: Stream Requested does not Exist
Spoot51 Aug 24, 2007 6:47 AM (in response to Spoot51)Thanks for the leads, Jeff. I am not able to export elementary streams using VOB2MPG, and in any case, Encore simply freezes when I import any file from VOB2MPG. I will try one of your suggested solutions.
Can you explain why the re-name process would work on some homemade DVDs and not others? Does it have anything to do with DVDs authored in non-Adobe programs??
also, why will the renamed files play perfectly in Windows Media and WinDVD, yet not go into Encore as .mpg assets?
Lots of questions; just curious as to how things work! -
3. Re: Stream Requested does not Exist
(Ray_Krzeminski) Apr 2, 2008 5:43 AM (in response to Spoot51)I had the same issue and to fix it I created a new file from the old one with the following settings.
File type: MPG
Codec: Ulead MPEG.Now Encoder
Media Type PAL DVD
Frame type: Upper Field First
Bit Rate: 5000 kbps
That worked for me!
