3 Replies Latest reply on Nov 24, 2008 10:46 AM by bregent
    PDF files not showing in IE
    spycatcher69
      Hello all first time post.
      I have a problem I cant seem to get my head around.I have created a web site for our local yacht club , on the links page I have added links to PDF files ,I am using dreamweaver 8 .
      The Pdf links work fine in firefox but not in IE ,I have changed file names ,put files in root directory ,remade the pdf document as a html even the link still will not work , However if a create a flash button to the pdf link it works fine in both browsers.I even created the page in fireworks and added a link in fireworks ,and it still wont work .
      I created the PDF files from a word document using acrobat 7.
      All security settings are ok ,this happens on all computers .I have tried the file on 4 different ones with different versions of IE.The View pdf in browser is enabled on all machines, as well as in acrobat.I also tried this link and tested the acrobat file it loads ok in IE http://windowsxp.mvps.org/ie/pdf.htm.I am trying this offline before I upload to server.
      Thank you all for your time and consideration.
      Peter
        • 1. Re: PDF files not showing in IE
          Level 7
          "spycatcher69" <webforumsuser@macromedia.com> wrote in message
          news:ggdo55$13m$1@forums.macromedia.com...
          > to server.
          It's unlikely anyone will be able to help you until you upload it.
          Tim G.
          http://www.pactumweb.com
          http://www.shortordersite.com
          • 2. Re: PDF files not showing in IE
            Level 7
            > to server.
            > Peter
            Make sure your server has the correct MIME type for PDFs.
            Dooza
            Posting Guidelines
            http://www.adobe.com/support/forums/guidelines.html
            How To Ask Smart Questions
            http://www.catb.org/esr/faqs/smart-questions.html
            • 3. Re: PDF files not showing in IE
              bregent Most Valuable Participant
              Possibly a security issue with IE opening local files. Try uploading to a webserver and see if you have the same problem.
