1 Reply Latest reply on Sep 1, 2008 9:29 PM by Traced67
    UninitializedError with Flex Component Kit
    Traced67 Level 1
      Hi erverybody,
      I am right know encountering a very annoying bug which drives me nuts by avoiding me to use Flex Component Kit.
      I did a test file in flash with just a rectangle symbole that I converted to a MovieClip with the name "MyTestClass". I selected it in the library and used the "convert symbol to flex component" command. I published the .swc file and put it in the library path of my Flex project.
      If I try to insert it in my mxml page I have only the UninitializedError hint in place of the MyTestClass:
      <local:UninitializedError />
      If I declare a namespace for my .swc:
      xmlns:flcomps="*"
      I also get the UninitializedError:
      <flcomps:UninitializedError />
      If I create a normal class file in a folder "components" in the src folder, I can reference it without problem:
      xmlns:comp="components.*"
      <comp:MyTestClass />
      I am right now totally unable to import any Flash MovieClip into Flex !!!!
      I followed the steps provided into this video:
      http://tv.adobe.com/#v=http%3A//adobe.edgeboss.net/flash/adobe/adobetvprod/under_the_hood_ with_adobe/35_uha_004.flv%3Frss_feedid%3D1052%26xmlvers%3D2
      Does anyone encountered this bug and got a solution? I already uninstalled/reinstalled Flash CS3, Flex Builder 3 and the Flex Component Kit...
      Many thanks for all the help you can bring me...
      Best regards
        • 1. UninitializedError with Flex Component Kit
          Traced67 Level 1
          That's really weird!
          After digging around, reinstalling Flash CS3 again and doing multiple tests, I finally found the source of the problem:
          Two .swc files residing in the same folder where I was saving my tests files were avoiding the Flash compiler to successfully create new .swc files!? I cannot understand how this can be possible. As soon as I choosed a new folder for saving the test files, I could link to the .swc and access the component from Flex. Also as soon as I moved out the two culprid files I could again save in the previous folder...
          Does anyone has an idea how this can happen?
          For those interested in the case, you can download the 2 culprid files here
          Best regards,
