2 Replies Latest reply: Aug 17, 2011 2:36 AM by Chatwinmic20 RSS
    Recording from internet results in echo
    Rich McN Community Member
      I tried to record a song from last.fm and youtube. While recording there is an echo sound and/or a delay in the tracks. I've posted this as a bug in Papago. This sound delay does not occur when I use AVS Media to record. This is a major problem
        • 1. Re: Recording from internet results in echo
          _durin_ Employee Hosts
          I suspect you've got the "Monitor Input During Recording" option selected in the record dialog. If you're capturing the streaming audio via the "What You Hear" or "Stereo Mix" input options in the Windows Sound Device preferences AND the input monitor option is turned on, Soundbooth will echo what it records through the main system output, which will then in turn be recorded as it's fed back into Soundbooth. Unchecking the Monitor... box should prevent that.
          If not, let me know and we can continue troubleshooting.
          Durin
          • 2. Re: Recording from internet results in echo
            Chatwinmic20 Community Member
            If you are trying to use Soundbooth or a streaming audio recorder program to rip sound from YouTube or Last.fm, what you have recorded should be original like what you tune in. You may need to check the speakers settings like stereo mix or set the recorder to record what you hear. I have never come across such a question.
