1 2 Previous Next 77 Replies Latest reply on Feb 12, 2011 6:27 PM by ColdSteele Go to original post
      • 40. Re: Soundbooth CS4 crashes on startup
        romgen Level 1
        For the devs, here is the output from GPUSniffer.exe (was in the Soundbooth folder) so you can rule out gfx card problems:
        D:\Program Files (x86)\Adobe\Adobe Soundbooth CS4>GPUSniffer.exe
        Device: 005F7FDC has video RAM(MB): 256
        Vendor string:    NVIDIA Corporation
        Renderer string:  GeForce 8500 GT/PCI/SSE2
        Version string:   2.1.2
        OpenGL version as determined by Extensionator...
        OpenGL Version 2.0
        Supports shaders!
        Supports VUYA Shader -> BGRA
        Supports UYVY/YUYV ->BGRA Shader
        Supports YUV 4:2:0 -> BGRA Shader
        Use basic OpenGL (aka CPU mode) only!
        Completed shader test!
        Internal return value: 7
        • 41. Re: Soundbooth CS4 crashes on startup
          _durin_ Adobe Employee
          If this is indeed related to the OpenGL issues seen in some Nvidia and Intel drivers, there's a few things to try.  First, I'd make certain you're completely up to date with your video drivers.  Second, as a test to rule this issue out, try temporarily moving or renaming the files
          nvoglv32.dll
          nvoglv.dll
          in your \windows\system32\  directory.  If Soundbooth still fails on the next launch, move them back.
          I would also recommend contacting Adobe Technical Support as these install/launch issues are significantly faster to troubleshoot and solve over the phone than they are here on the forums.  If you'd prefer to keep it here, can you provide any additional information about the crash behavior?  Do you get error messages?  Do you see the Soundbooth splash screen pop up before the crash?
          Durin
          • 42. Re: Soundbooth CS4 crashes on startup
            romgen Level 1
            Hello,
            actually I had to look into my CS Box to find the customer support information, never thought of that (I am more accustomed to Internet communication).
            Regarding my problem: I renamed the files (for me it was in the WOW64 folder since Soundbooth is 32bit) and it's crashing behavior didn't change.
            Regarding more information: I see the splash loading several modules (around 10 seconds) until I get the famous "report this crash to Adobe" screen. The only weird thing is that I can successfully run Soundbooth through the WinDbg application, but for me it's not an option on the long term of course (starting the application through a debugger).
            By the way: I installed Soundbooth on a 2nd portable computer (as the license allows) which got XP (32bit) installed, and it worked fine. So that rules "ruined DVD medium" out I guess.
            Thanks for your effort
            • 43. Re: Soundbooth CS4 crashes on startup
              RiumaPI
              Hi, I've the same problem with Soundbooth, Media Encoder and Premiere; I've see that the crash start when all the programs loading "ExporterAVI.prm" plug-in...Can you help me?!?!?
              Thx
              • 44. Re: Soundbooth CS4 crashes on startup
                MPGillespie
                This happens to me, too...always when it reaches the "loading PlayerMediaCore.prm" line on the splash screen. Have tried the workarounds suggested earlier in this thread with no luck. Any suggestions?
                • 45. Re: Soundbooth CS4 crashes on startup
                  xcv1001
                  I had problem with Adobe After Effects CS4, Adobe Encore CS4, Adobe Photoshop CS4, Adobe Soundbooth CS4, Adobe Premiere Pro CS4 and I fixed everything!!!!!!!
                  My Hardware/Software profile:
                  - Intel Pentium 4
                  - Go Fx 5700
                  - Windows XP SP3
                  Problems in details :
                  1- With Soundbooth and Premiere  I had problem loading up- Splash screen only used to go up to loading "PlayerMediaCore.prm" then just shuts down.
                  2. With AfterEffects It was error 0::42
                  3. With Potoshop it used to crashed as soon as it opened .
                  Diagnose:
                  The issue was with the display card drivers and Open Gl
                  Solution:
                  As Durin said to delete nvoglv32.dll , nvoglv.dll. It worked and only for Soundbooth and Premiere but Photoshop and AfterEffects still did not work.
                  I couldnt find latest driver for my card  last release was 2004 on HP website.
                  However I found this site which has all the NIVIDA drivers.
                  http://www.warezthegfx.com/games/102028-nvidia-drivers-updated-21-03-09-a-post105989.html (Choose according to your system)
                  To Install you must know what type of card you have.
                  1. Download the file and extract it- The setup will being on it own. If the setup says "The NIVIDA setup program could not locate..............."  and exit , do not worry.
                  2. Go to your Device manager and select your display adapter
                  3. Under Driver "select uninstall"  and uninstall your drivers then restart system
                  4. Go back to Device manager and select your VGA card
                  5. Under Driver select Update driver and choose "Install from a list or a specific location"
                  6. Hit next then select "Don't search....."
                  7. Click on Have disk or browse and point to the files that you extracted from the download
                  8. Tick off show Compatible hardware
                  9. Choose your card, and install it , even if u get any warning ! But make sure u know what card u have.
                  I hope it works coz it worked for me!  Good luck to all!
                  • 46. Re: Soundbooth CS4 crashes on startup
                    romgen Level 1
                    Actually this is how I solved the Soundbooth crash:
                    a) Format harrddisk (yes, i did that)
                    b) Complete _fresh_ install of Windows
                    b1) Install GFX card drivers from webpage
                    c) Install all patches, updates AND redist packs from Microsoft webpage
                    d) Install Adobe products
                    e) install updates for adobe products
                    It also seems that the ORDER of doing this things is important (Adobe at last)
                    Now it works all fine. A bit work intensive but anyway ;-)
                    • 47. Re: Soundbooth CS4 crashes on startup
                      ccoltman
                      Well I had this problem in Windows 7, it was a simple fix based on a problem with the ExporterAVI Plug-in.
                      In the \[install directory]\Adobe Soundbooth CS4\Plug-ins\Common folder there is a file called Blacklist.txt, I simply added the offending plugin to the list ("ExporterAVI") and was able to launch Soundbooth again.
                      Much as the people here want you to go through an inquisition about your OpenGL drivers and have you reinstalling entire operating systems, it boiled down to a simple plugin.
                      • 48. Re: Soundbooth CS4 crashes on startup
                        Donny_M Level 1
                        Matt, I am wondering what the shift key does in this case. I have been having the problem of the program crashing when ever I wanted to do a multi-track file, I help the shift key down at start up and it seems to be working now. I unlike the everyone else run a Mac with OSX Snow Leopard, I hadn't had the problem until I updated to Snow Leopard.
                        • 49. Re: Soundbooth CS4 crashes on startup
                          Holding down SHIFT on launch bypasses the preference files, loading the internal defaults.  If Soundbooth is then exited cleanly, the "new" preferences (whatever state they are in when the application is closed) are written to the Preference files.
                          • 50. Re: Soundbooth CS4 crashes on startup
                            Donny_M Level 1
                            Thanks for the info Matt, everything seems to be working great now.
                            • 51. Re: Soundbooth CS4 crashes on startup
                              cornelhecht
                              Hello,
                              I've the same problem with Soundbooth, Media Encoder and Premiere; I've see that the crash start when all the programs loading "Audio only"-
                              always when it reaches the "Audio only" line on the splash screen.
                              Can you help me?
                              Thx
                              Cornel
                              • 52. Re: Soundbooth CS4 crashes on startup
                                xcv1001 Level 1
                                what kind of graphic card u got?
                                • 53. Re: Soundbooth CS4 crashes on startup
                                  cornelhecht Level 1
                                  I have RADEON X600 graphic card.
                                  • 54. Re: Soundbooth CS4 crashes on startup (WinPathUtils.cpp-582)
                                    d_atkins
                                    I get the error WinPathUtils.cpp-582
                                    C:\Documents and Settings\djatkins>set
                                    ALLUSERSPROFILE=C:\Documents and Settings\All Users
                                    APPDATA=\\BETA\djatkins\.windows\Application Data
                                    CommonProgramFiles=C:\Program Files\Common Files
                                    FP_NO_HOST_CHECK=NO
                                    HOMEDRIVE=C:
                                    HOMEPATH=\Documents and Settings\djatkins
                                    HOMESHARE=\\beta\djatkins
                                    LOGONSERVER=\\BETA
                                    OS=Windows_NT
                                    Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\system32\WindowsPo werShell\v1.0;C:\Program Files\QuickTime\QTSystem\
                                    PROCESSOR_ARCHITECTURE=x86
                                    PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
                                    PROCESSOR_LEVEL=6
                                    PROCESSOR_REVISION=0f0b
                                    SystemDrive=C:
                                    SystemRoot=C:\WINDOWS
                                    TEMP=C:\DOCUME~1\djatkins\LOCALS~1\Temp
                                    TMP=C:\DOCUME~1\djatkins\LOCALS~1\Temp
                                    USERDOMAIN=OZ
                                    USERNAME=djatkins
                                    USERPROFILE=C:\Documents and Settings\djatkins
                                    windir=C:\WINDOWS
                                    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
                                    "AppData"="\\\\BETA\\djatkins\\.windows\\Application Data"
                                    "Cookies"="C:\\Documents and Settings\\djatkins\\Cookies"
                                    "Desktop"="\\\\BETA\\djatkins\\.windows\\Desktop"
                                    "Favorites"="C:\\Documents and Settings\\djatkins\\Favorites"
                                    "NetHood"="C:\\Documents and Settings\\djatkins\\NetHood"
                                    "Personal"="\\\\BETA\\djatkins\\.windows\\My Documents"
                                    "PrintHood"="C:\\Documents and Settings\\djatkins\\PrintHood"
                                    "Recent"="C:\\Documents and Settings\\djatkins\\Recent"
                                    "SendTo"="C:\\Documents and Settings\\djatkins\\SendTo"
                                    "Start Menu"="C:\\Documents and Settings\\djatkins\\Start Menu"
                                    "Templates"="C:\\Documents and Settings\\djatkins\\Templates"
                                    "Programs"="C:\\Documents and Settings\\djatkins\\Start Menu\\Programs"
                                    "Startup"="C:\\Documents and Settings\\djatkins\\Start Menu\\Programs\\Startup"
                                    "Local Settings"="C:\\Documents and Settings\\djatkins\\Local Settings"
                                    "Local AppData"="C:\\Documents and Settings\\djatkins\\Local Settings\\Application Data"
                                    "Cache"="C:\\Documents and Settings\\djatkins\\Local Settings\\Temporary Internet Files"
                                    "History"="C:\\Documents and Settings\\djatkins\\Local Settings\\History"
                                    "My Pictures"="\\\\BETA\\photos"
                                    "Fonts"="C:\\WINDOWS\\Fonts"
                                    "My Music"="\\\\BETA\\djatkins\\.windows\\My Documents\\My Music"
                                    "Administrative Tools"=""
                                    "CD Burning"="C:\\Documents and Settings\\djatkins\\Local Settings\\Application Data\\Microsoft\\CD Burning"
                                    "My Video"="\\\\BETA\\djatkins\\.windows\\My Documents\\My Videos"
                                    If I log on as a Non-Domain ie Local User it works
                                    • 55. Re: Soundbooth CS4 crashes on startup
                                      ashley giles
                                      f it identifies any file or setting to be damaged, missing, or corrupted, it provides you with an updated list of the same and also repairs these errors. Therefore, if your computer keeps crashing and need to fix blue screen of death a good registry cleaner is all you need. Your computer can also cause problems because of redundant files in its registry. Reg cleaners identify all these redundant and junk files that were left over during the uninstalling process of hardware of software and delete them. This makes sure that the "computer keeps crashing" issue is taken care of.
                                      __________________________
                                      Free Sound Effects
                                      • 56. Re: Soundbooth CS4 crashes on startup
                                        ktvmobile Level 1
                                        I had the same problem with Soundbooth crashing on startup after PlayerMediaCore was seen on the splash screen.
                                        A post above about the file called Blacklist.txt gave me the idea to move all of the plug ins to another folder and start the program. Replace them one by one, loading the program after each plug in was moved back into the original folder. The program would not load when the plug in called ImporterFastMPEG was loaded back into its original folder. I can run the program without it.
                                        Thank you Adobe for this forum and thank you to all of you who chose to post here. You have helped more than you could ever know.
                                        • 57. Re: Soundbooth CS4 crashes on startup
                                          ccoltman Level 1
                                          You're quite welcome Deacon_1, it's nice when a quick easy fix is the one you actually needed. I don't appreciate the "wipe and reinstall" mentality that prevails on the net these days. Glad it fixed you up!
                                          • 58. Re: Soundbooth CS4 crashes on startup
                                            CFlyer
                                            I could not start soundbooth yesterday.
                                            So I tested a solution that I has used to get Encore to start.
                                            I renamed the directory: C:\Documents and Settings\UserName\Application Data\Adobe\Adobe Soundbooth\2.0 to C:\Documents and Settings\UserName\Application Data\Adobe\Adobe Soundbooth\2.0_Old.  I later deleted the library.
                                            After that Soundbooth started.
                                            I still do not know what caused the problem.
                                            Anyone any idea what is happening?
                                            • 59. Re: Soundbooth CS4 crashes on startup
                                              michaelbfeig
                                              Just got done fixing a problem with the exporteravi.prm plugin and I thought I would share the experience for those who may run into the same problem.  Basically, after updating Premiere and After Effects, these programs (plus soundbooth) would crash on load.  I noticed that it would always crash while loading  exporteravi.prm, so I found the file in each applications directory and removed it.  After doing so, all three programs worked.
                                              Michael Feig
                                              http://www.chicagovideowork.com
                                              • 60. Re: Soundbooth CS4 crashes on startup
                                                bryanbloodsoaker
                                                I found that my CS4 Soundbooth 2.0.1 startup crash problem was resolved by simply uninstalling Quicktime (as Durin has mentioned), after all of the other trouble shooting methods failed on me.  After the uninstall, Soundbooth loaded up perfectly and did not crash during its startup and allowed me to edit some audio files successfully.  I haven't tried to reinstall Quicktime yet, to see if the crash reoccurs again, but maybe Soundbooth just prefers to have Quicktime uninstalled and then reinstalled again (after the initial Soundbooth installation)?  Everybody's computer seems to have its own individual resolution for the Soundbooth crash problem, so one just has to experiment a little to see which fix actually works.  Good luck to future crash problems!
                                                • 61. Re: Soundbooth CS4 crashes on startup
                                                  Lewie311
                                                  I too had/have the same issue.  Uninstalled quicktime - Soundbooth worked like a charm.  Re-installed quicktime, Soundbooth back to crashing after opening just long enough to make me excited...then...psyche!!
                                                  • 62. Re: Soundbooth CS4 crashes on startup
                                                    Emma87 Level 1
                                                    I am getting the same problems. i keep getting a Soundbooth Startup  error "Soundbooth could not find capable video playback modules"etc....
                                                    I am running on Windows 7 64 bit, with a  radeon HD 5600 graphics card.
                                                    I have tried downloading  the latest drivers, reinstalling soundbooth, doing a system restore,  moving/renaming folders and files, holding down shift etc and to no  avail.
                                                    I tried loading it in safemode too which partially worked,  ie i could see the interface but the it got a critical error and crashed.
                                                    Any help or advice would be appreciated
                                                    • 63. Re: Soundbooth CS4 crashes on startup
                                                      xcv1001 Level 1
                                                      u have to see what sort of error is it?
                                                      • 64. Re: Soundbooth CS4 crashes on startup
                                                        Emma87 Level 1
                                                        That is the error message that comes up on the screen. It fails whilst hanging on loading playerMediaCore.prm, which is displayed on the soundbooth splash screen. I get a similar error if i try and load premiere. Before the first time i got the error i also got a system error saying that the GPUSniffer.exe was not working properly, is this related?
                                                        • 65. Re: Soundbooth CS4 crashes on startup
                                                          xcv1001 Level 1
                                                          Find the playerMediaCore.prm and move it to a new location..and whtaever
                                                          other plugins, while loading, causes the program to crash, move them too.
                                                          Also check the http://premierepro.wikia.com/wiki/Troubleshooting
                                                          Adobe CS4 suit has way over too many bugs, If u see the forums u
                                                          see everyone is complaining.
                                                          I wish i cud be more help
                                                          Good luck!
                                                          Ab.A
                                                          • 66. Re: Soundbooth CS4 crashes on startup
                                                            Emma87 Level 1
                                                            thanks but that didn't help, just failed faster
                                                            • 67. Re: Soundbooth CS4 crashes on startup
                                                              Please move the playerMediaCore.dll BACK where it was.  While many plug-ins can certainly be removed for troubleshooting, this happens to be the backbone of the media player in all of the CS4 suite applications and is required.
                                                              Generally, the DLL displayed in the startup screen tends to be the last one to successfully load.  The error messages you've posted and described indicate an issue with the video driver - chiefly that it is not reporting OpenGL support, which is a graphics acceleration library included with most video drivers.  Unfortunately, the drivers installed by Windows tend to be basic and not support the advanced features of a video card that the manufacturer's drivers would.  My first recommendation would be to visit the website of the manufacturer of your video card, for example ATI or Nvidia, and install the latest drivers for your video device.  For your Radeon HD 5600, you can find the latest ATI driver at http://support.amd.com/us/gpudownload/Pages/index.aspx
                                                              I suspect this will resolve your issue, Emma, or at least get beyond the error you've posted so we can continue troubleshooting.
                                                              • 68. Re: Soundbooth CS4 crashes on startup
        Emma87 Level 1
        I have tried that, completely removed them and put them back. It was working perfectly fine then it just stopped working. The first thing that came up was a GPUSniffer.exe error, and then i couldn't load soundbooth or premiere. I have tried restoring my system and it didn't work, which leads me to believe its a file on the system that isn't getting removed with a restore or reinstall. Any ideas what it could be?
        If i try and run the sniffer its come up with a not working error
        I have seen on a lot of forums illustrating problems with it breaking.
        • 69. Re: Soundbooth CS4 crashes on startup
        jbarker3887
        I'm having this issue with none of the suggested fixes working.  I opened Event Viewer for Applications and notice that whenever I attempt to launch Soundbooth and it crashes before opening a Windows Search Service error is logged to the Event Viewer.
        Event ID: 3083
        Description:
        The protocol handler Groove.SearchProtocolHandler.1 cannot be loaded. Error description: A dynamic link library (DLL) initialization routine failed. .
        Any ideas???
        • 70. Re: Soundbooth CS4 crashes on startup
        Emma87 Level 1
        i am not sure, it may just be saying saying that one of the many ddl files is corrupt
        for some reason. I now believe it to be my graphics card becuase if i disable it soundbooth works fine, very odd.
        • 71. Re: Soundbooth CS4 crashes on startup
        Are you running Microsoft Office Groove ?  I'm not very familiar with the tool, but if that error comes up in Event Viewer every time you try to launch Soundbooth, it is a very suspicious target.
        • 72. Re: Soundbooth CS4 crashes on startup
        xcv1001 Level 1
        No man im not!
        • 73. Re: Soundbooth CS4 crashes on startup
        megadoosh
        Post number 47 is the solution.
        You have to add the offending plugin to the Blacklist.txt file.
        Launch crashing program and pay attention to the last plugin that you see.
        Add it to the Blacklist.txt file without the extension.
        Bada bing. You're gold.
        • 74. Re: Soundbooth CS4 crashes on startup
        bkmvl Level 1
        I have SB cs5 and it does not crash when i start just not finishing loading, i get loading playermediacore.prm then nothing,
        i moved the nvoglv32.dll from \windows\system32 and that helped, question is how much else is broken now
        I use Win 7 ultimate-N 64 bit, i added some media stuff from microsoft to get the mediaplayer and codecs i guess so i could run
        songbird, and the performance index in windows, at that point sb stopped working.
        • 75. Re: Soundbooth CS4 crashes on startup
        medicgordo
        Thank you so much guys.  I was racking my brain, pulling what's left of my hair out trying to figure this one out...then I read this posting about Quicktime.  I remembered that I reluctantly installed Quicktime a few months ago.  I tried uninstalling it, restarted the computer and Soundboth CS5 WORKS PERFECTLY!!!  I should have never installed anything from Apple which is my normal policy but I got reckless.  THANKS AGAIN!
        • 76. Re: Soundbooth CS4 crashes on startup
        JaydenLawson
        Deacon_1 had the answer that worked for me!   Thanks mate! I'm on Windows 7 on a MacBook Pro.  I just moved the ImporterFastMPEG.prm plug-in from the Plug-ins\Common folder - back to the root directory of the Soundbooth installation, and it all loads fine now!
        Strange problem though.  Before this fix, Soundbooth didn't open 3 times, then it opened, then it didn't, then it did... and after that it never opened again.
        Thanks Deacon_1 and ccoltmanhttp://forums.adobe.com/people/ccoltmanhttp://forums.adobe.com/people/Deacon_1
        • 77. Re: Soundbooth CS4 crashes on startup
        ColdSteele
        im getting the splashscreen issue, says loading PlayerMediaCore.prm and just sits there... i tried the blacklist thing and got past it to the NV_OGL error, i have nvidia w/ cuda, its a gtx 280 with driver version 266.58 (current) and even tried a fix i saw on nvidia forums about the nvoglv32.dll being inghte wrong spot. when i check the plugin loading oog the last entry is...
        Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\PlayerMediaCore.prm
        There was an error loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\PlayerMediaCore.prm from the plugin cache
        The registry key will be deleted and the plugin will be loaded from disk.
        Loading from disk..."
        plenty other plugin load from the "disk" fine...
        "Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterMp3.prm
        This plugin was recognized by loader ba1058cd-0007-44e4-bf1a-0ef51307b979.
        Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterMPEG.prm
        Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterQT.prm
        Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterWave.prm
        This plugin was recognized by loader ba1058cd-0007-44e4-bf1a-0ef51307b979."
        ive checked the plugin folder and the .prm file is there... so im stuck. any thought.
        1 2 Previous Next
