12 Replies Latest reply: Feb 25, 2008 1:55 PM by (Chad_Garber) RSS
    Problems installing trial
    RoboWizard CommunityMVP
      Hi all
      Just installed Visual Communicator and it is prompting for a serial number. Or, I may choose to continue in trial mode. Selecting the trial mode refuses to work.
      From the looks of this forum, I'm guessing the product is new enough that there aren't many posts so far. I'm really active in the Captivate forums (known as Captiv8r there) and the RoboHelp forums (known as RoboWizard there).
      Anyone aware of workarounds for this or is it another one related to the new and more secure licensing model?
      Cheers all... Rick :)
        • 1. Re: Problems installing trial
          Community Member
          Could you give us the specific error message you get when the app refuses to work?
          Just to be clear, you were able to successfully select "Run as trial" when the app first launched and asked you for a serial number, but it quit shortly after?
          • 2. Re: Problems installing trial
            Hi Matt
            No, it has never worked. Upon installing, I elected to select the option to try it for 30 days. It attempts, but encounters something that kicks me back to the screen where I made the choice. But the choice at that point is only to enter a valid serial number.
            I saw the same thing with the Captivate trial and never did manage to make the trial work on my PC. Ended up having to plug in a serial number to continue.
            Thanks... Rick :)
            • 3. Re: Problems installing trial
              Community Member
              Hmm, it sounds like an issue with the licensing/activation tech, especially if you had the same issue with the Captivate trial.
              I assume you downloaded the trial from the Adobe website?
              I can't personally offer any further help since that's a little out of my area of expertise, but I'll see if I can ask around and get an answer/workaround for you.
              • 4. Re: Problems installing trial
                Hi all,
                I'm experiencing the same problem with the trial version of Captivate 3 - i install it and run it for the first time, and when i select the trial option, the following error comes up -
                "A problem was encountered while trying to load the trial period for Adobe Captivate 3.
                Click Quit to see if restarting your computer or re-installing the software fixes the problem. Otherwise, click Continue to display a screen where you can enter a valid serial number to begin using the product without trial."
                On clicking continue, it throws me back to the previous screen, greying out the trial version option.
                I reinstalled and restarted, and the problem persists. Any ideas?
                • 5. Re: Problems installing trial
                  Hi Malcolm
                  You should probably post this in the Captivate user forums. They are located at
                  http://www.adobe.com/cfusion/webforums/forum/index.cfm?forumid=67
                  You may also wish to contact Support.
                  Cheers... Rick :)
                  • 6. Re: Problems installing trial
                    Community Member
                    Cheers Rick, will do. :)
                    • 7. Re: Problems installing trial
                      Hello All,
                      Any update on this issue? I'm getting the same error message.
                      I want to try but when I choose the 30 day trial, I get a "Product Trial Error"
                      Does anybody know if Adobe has temprary Serial numbers?
                      • 8. Re: Problems installing trial
                        Hi there
                        Personally, I never was able to resolve it and had to acquire the full version. Fortunately, the full version worked fine. The software is neat.
                        I don't believe Adobe has any "temporary" serial numbers. Once you enter a valid serial number, it's good to go from here forward.
                        Sincerely... Rick :)
                        • 9. Re: Problems installing trial
                          Hello I have visual communicator pro 2 and the theme pack 1. I changed my computer it has Windows Vista. I was trying to install VC but nothing happened. Any suggestions? I will appreciate it.
                          Thank you
                          Gonzalo Andrade
                          • 10. Re: Problems installing trial
                            Community Member
                            Gonzalo I too had Visual communicator pro 2 and Vista.
                            Adobe will not provide a license to work with Vista.
                            I worked hard to install it and asked tech support for help also.
                            There is no way that I know of to make it work.
                            The good news is Visual Communicator 3 works well with Vista 32 bit and 64 bit. The upgrade is $149. I am happy I upgraded.
                            • 12. Re: Problems installing trial
                              Community Member
                              None of the adobe trials are working for me. They all say that the trial version has run into problems forcing me to select 'buy now'. I have called Adobe numerous times on this issue but noone has helped. I starting to serioulsy think that Adobe is doing this on purpose so people will just buy the software.
