3 Replies Latest reply on Jun 14, 2010 1:55 PM by tomj
    is data passed back to responder a read-only copy?
    mitchgrrt
      I have a service that I call, adding a responder:
      var modelingDataResponder:IResponder = new ModelingDataResponder();
      var modelingDataService:DataService = EnterpriseServiceLocator.getInstance().getDataService("ModelingDataService");
      var token:AsyncToken = modelingDataService.fill(myModel, clientName);
      token.addResponder(modelingDataResponder);
      This causes the variable myModel to be filled. It adds a responder called modelingDataResponder which implements IResponder. modelingDataResponder is called when the fill completes.
      My question is this. modelingDataResponder is called with data that's a copy of the myModel object that was filled. But it seems to be only a copy. It seems like executing code inside modelingDataResponder that changes data fields inside the parameter that is passed in just changes the data in a local copy, not in the myModel object that was filled. The two objects have separate addresses when looked at in the debugger, and changing a value in one has no effect on the other.
      So it's like the data that is passed back is a copy. The copy can be read. Writing in the copy is OK, but it is just writing on a copy, on on the object that was filled. Right?
        • 1. Re: is data passed back to responder a read-only copy?
          jeffvroom
          I think that this is a bug... I think that today the responder's token is receiving the raw array of objects received from the server. It should be given the same object - i.e. the "myModel" object -- in the result event. I'll make sure a fix gets into the next release. In the meantime, a workaround would be to do:
          token.myResult = myModel
          just after the fill call... then use "myResult" instead of token.result.
          • 2. Re: is data passed back to responder a read-only copy?
            SiebeD
            Hi Jeff,
            We use LiveCycle Data Services ES 2.6 and we currently have this  issue.
            When using LiveCycle Data Services ES 3.0 (I only replaced  following swc's: fds.swc and airfds.swc) we don't have this problem any  more.
            Thanks for the workaround.
            We still have a few questions could you answer these for me?
            - Since what version of LCDS is this issue resolved?
            - Is their a Jira issue for this?
            - Is a patch available?
            • 3. Re: is data passed back to responder a read-only copy?
              tomj Adobe Employee
              LCDS 3.0 and above.
              No, as we use an private bug tracking system for LCDS.
              No, sorry.  You would have to work through Adobe Technical support to get a hotfix for this, and I do not believe that one exists.  I would recommend upgrading to 3.1 if you can.
              Tom
