3 Replies Latest reply on Sep 3, 2008 8:15 PM by Newsgroup_User
    Multiple Source Validators
    BrandG
      I have two edit boxes, "Password" and "Password Confirm". I want to use Flex's validators correctly wherever possible, and this looks like an obvious choice. However, if I make a custom validator, it has only one source passed to it. Is there any way to read from both sources in a validator? Or should I just punt and fake a validation errortip when the user submits invalid data?
        • 1. Re: Multiple Source Validators
          Level 7
          "BrandG" <webforumsuser@macromedia.com> wrote in message
          news:g9mu7u$5cl$1@forums.macromedia.com...
          >Flex's
          > choice.
          > it. Is
          > punt
          I just define the validator and don't use the source. Instead, I use
          something like this:
          //when the focus leaves a control connected to a DataItem
          private function dataItemFocusOut(di:DataItem, e:Event):void{
          var result:ValidationResultEvent;
          if (di.validatorType=='StringValidator'){
          var sV:StringValidator=sValidator;
          sV.minLength=di.minLength;
          sV.maxLength=di.maxLength;
          sV.listener=e.currentTarget;
          sV.required=di.isRequired;
          result = sV.validate(e.currentTarget.text);
          } else if (di.validatorType=='EMailValidator'){
          var eV:EmailValidator=eValidator;
          eV.listener = e.currentTarget;
          eV.required = di.isRequired;
          result = eV.validate(e.currentTarget.text);
          } else {
          trace('this code doesn\'t provide a validator of type
          "'+di.validatorType+'".');
          var dontValidate:Boolean=true;
          if (result.type==ValidationResultEvent.VALID){
          di.isValid=true;
          di.value=e.currentTarget.text;
          } else if (!dontValidate) {
          di.isValid=false;
          The mxml that makes it work looks like this:
          <mx:FormItem label="First Name *">
          <mx:TextInput id="firstName" width="250" text="{contactDetails.firstName}"
          focusOut="dataItemFocusOut(contactDetails.firstName, event)"/>
          </mx:FormItem>
          HTH;
          Amy
          • 2. Re: Multiple Source Validators
            BrandG Level 1
            Amy, you are a focused ray of helpful win.
            So thorough, specific, and quick, it's almost like you had the code on hand already.
            Seriously, thanks. I probably would have spent a week digging into the Flex source to build my own validator descendant. :)
            • 3. Re: Multiple Source Validators
              Level 7
              news:g9n007$76b$1@forums.macromedia.com...
              > hand
              > already.
              > Flex
              You're welcome :-)
