• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Mixing frame from other slide
New Here ,
Aug 18, 2008 Aug 18, 2008
I have the following problem, I have a project 9 minutes long, 120 slides and when I see all together (project), for example in slide 28 I got frame of slide 10?
If I click on key F10 (5 slides) starting on slide 28 I don't see that frame, but when I hit F8 (all project) it happens??
Help!!!
Gustavo
TOPICS
Getting started
Views
446
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor ,
Aug 19, 2008 Aug 19, 2008
Sound as if you have the image used a s a frame on slide 10 set to "display for rest of project" and not display for rest of slide.
If you then preview the project from anywhere after slide 10 you will not see the frame. To see it you need to view entire project (F4) or from slide 10 itself.
When the project is published the frame will show for the whole project if you have chosen the settings I mention above.
If you don't want to see the frame from slide 10 on slide 28 etc set the 'display for' option to 'rest of slide' NOT 'project' in the properties of the frame object
Regards
Webbo (UK)
Votes
Translate
Translate
Report
Report
New Here ,
Aug 20, 2008 Aug 20, 2008
LATEST
Hi Webo,
Thank you for your time writing me; I double check if by mistake I had changed to “Display for rest of project”, but all the slides were recorded as “display for rest of slide”.
I’ll contact support??
Thank you again,
Gustavo
Votes
Translate
Translate
Report
Report
Resources
Help resources
