3 Replies Latest reply on Sep 9, 2008 8:10 AM by MixMastaJames
    seperate AS file for flex project
    MixMastaJames Level 1
      I've just started using Flex, and although I love it, I hate having to scroll up all the time to edit the AS3 code in the <mx:Script> tags.. so i was wondering if there was a way to save out all the AS3 code to a seperate as file and tell the mxml file to use the code in that file.
      Thanks.
        • 1. seperate AS file for flex project
          EvolvedDSM Level 2
          Sure is! Rather than explain, I'll let Adobe do the talking.
          http://livedocs.adobe.com/flex/3/html/help.html?content=usingas_4.html
          "To make your MXML code more readable, you can reference ActionScript files in your <mx:Script> tags, rather than insert large blocks of script. You can either include or import ActionScript files."
          Hope this helps!
          EDIT:
          TL;DR version:
          add all your <script> code minus the SCRIPT and CDATA tags to an actionscript file. Then in your application, you'll need to include your new actionscript file using <script source="path_to_script.as"/>
          And that's it. I just tested on a small app of mine and works perfectly.
          • 2. Re: seperate AS file for flex project
            Level 7
            "New to AS3" <webforumsuser@macromedia.com> wrote in message
            news:ga5pgp$rb8$1@forums.macromedia.com...
            > scroll
            > file
            You can include it.
            Or, right click next to the first line of the script block (where the line
            numbers are) and select Add Bookmark..
            Then Window>Other Views...>General>Bookmarks
            HTH;
            Amy
            • 3. Re: seperate AS file for flex project
              Thanks for the replies.. I knew about the stinking include, just haven't used it since AS2 (write classes most of the time, but didn't want to do it with this). So DUH to me :)
              I did use bookmarks, but i really wanted to seperate out the different set of functions I had for each part of it into their own files.. which the include allowed me to do.
              Thanks again :)
