0 Replies Latest reply on Sep 8, 2008 3:20 PM by dimival
    Issue when converting java.util.HashMap into an ActionScript Object
    dimival Level 1
      I have this weird issue and i can't figure it out, let me explain:
      I have a java object A which has a HashMap variable myMap, this map will hold objects of class B. Inside B there is an instance of C class. In ActionScript i have the corresponding class A which has a variable myMap but since there is no HashMap in ActionScript its type is Object and i also have the corresponding classes B and C.
      [RemoteClass(alias="com.test.A")]
      public class A {
      public var myMap:Object; // this is the HashMap in Java
      [RemoteClass(alias="com.test.B")]
      public class B {
      public var id:Number;
      public var name:String;
      public var myC:C
      [RemoteClass(alias="com.test.C")]
      public class C {
      public var myId:Number;
      public var myName:String;
      I need to put the C objects of each B object of the map inside a DataGrid so i am obtaining the object of class A using a RemoteObject and then i iterate over the myMap property using a for each in loop, like this:
      for each(var i:* in objectA.myMap) {
      someArrayCollection.add(i.myC);
      The first issue appears here, suppose the java HashMap contains 3 elements, in the ActionScript loop i get 4 elements, the fourth one being a reference to the A object. In order to avoid this i use the "is" operator like this:
      if (i is B) {
      Now here is the real issue, when i do this the C objects contained in the B objects of the myMap property are reset to their initial values (myId is NaN and myName is empty string according to the C class). I changed the if condition to this and worked:
      if (!(i is A)) {
      When i did this the DataGrid shows the values of the C objects (myId and myName) perfectly fine. I did a little more testing and i "figured" out the issue, if i use an instance of class B anywhere in my application, the values of the C object are reset, for example:
      if (i is B) {
      var test:B = new B();
      This resets the C object (myId and myName) of each B object contained in the map of the A object which makes no absolute sense.
      So the thing is whenever i use the B class, which is the class of the objects inside myMap, the C objects are reset!!!! Does anyone know how to fix this?????
      I am using Flex 2.01 hotfix 3, i wonder if this is some kind of bug that was solved in a later release.
      Any help would be appreciated.
