1 Reply Latest reply on Oct 2, 2008 5:06 AM by jeffreypritchard
    XML socket
    aruvasavi Level 1
      Can I be able to use Socket connections if I am using firewall in my application??
      Thanks in advance
        • 1. XML socket
          Yes you can, but depending upon which firewall you use, you might have to set the rules in it to allow for your app to run. With McAfee's Firewall, I had to redo this each time I ran a new build (but only the first time after I compiled).
          That may not have been necessary, but I never found it to be much of a nuisance, so I never looked in to it further.
          Also, make sure if your socket isn't connecting there isn't a McAfee window buried behind another window waiting for you to say it is ok to open the socket (or the port the socket is on). Hope this helps.
