1 Reply Latest reply on Sep 10, 2008 1:11 AM by AndyTank
    Running a State Transition on Startup
      Hi there
      Trying to get my ap to change state on startup to run a transition animation. The idea is that this is a nice way to bring the ap to life, with some movement to bring the interface in.
      Is there a simple trick to do this?
      I have tried state=" startupState" in the WindowedApplication line which works for me in a Flex ap, but in Air produces a long list of complaints about transition effects under the category:
      TypeError: Error #1009: Cannot access a property or method of a null object reference
      I have tried creationComplete="state=' startupState'" but get the same result
      Any suggestions? I am quite new to this so may have missed something obvious, or perhaps there is a better way than using a state transition to run a bit of animation on the interface at startup?
      Any help much appreciated
        • 1. Re: Running a State Transition on Startup
          AndyTank Level 1
          The self-help bureau here...(!)
          Just in case anybody else is looking into this I have the solution...
          One of my Zoom transitions was set to a duration of zero. This plays happily in the Flex world
          In Air land on the other hand zero's are no-no's, so simply setting the duration to 0.001 resolved the issue
