6 Replies Latest reply on Sep 9, 2008 1:45 PM by wyattbiker
    Why doesn repeater work inTileList?
    wyattbiker
      I have an array of the 50 states names. I want to use a repeater to generate a button for each one. It doesn't work because what it doesn it places the buttonson top of each other in the top left cornr of the application.
      However if I list them out one Button at a time (E.g. <mx:Button label="Alabama"/>)this works fine.
        • 1. Re: Why doesn repeater work inTileList?
          Level 7
          "wyattbiker" <webforumsuser@macromedia.com> wrote in message
          news:ga3mot$ap4$1@forums.macromedia.com...
          >generate a
          > <mx:TileList id="States" height="250" width="666"
          > maxColumns="5" rowHeight="50" columnWidth="50" x="21" y="20">
          > <mx:dataProvider>
          > <mx:Array>
          > <mx:Repeater id="rp" dataProvider="{stateNames}" >
          > <mx:Button label="{String(rp.currentItem)}"/>
          > </mx:Repeater>
          > </mx:Array>
          > </mx:dataProvider>
          > </mx:TileList>
          The first mistake you made is to put a Repeater tag within an Array. This
          whole code snippet doesn't make enough sense that I can figure out what
          you're trying to accomplish. Could you back up, regroup, and say from the
          beginning what you want to see in your TileList?
          -Amy
          • 2. Re: Why doesn repeater work inTileList?
            wyattbiker Level 1
            I am trying to put 50 buttons, 5 per row, in a TileList.
            I have an array with labels to be assigned to each button's label. I didnt want to list each Button inidividually so i thought I would use a repeater. Can itbe done wtihout writing AS code?
            Also any reason why Repeaters don't work inside an Array? After all we are building an array of objects?
            • 3. Re: Why doesn repeater work inTileList?
              Level 7
              news:ga3rf6$g7i$1@forums.macromedia.com...
              > repeater. Can
              Just set up a dataprovider with the labels of the buttons, then set up
              Button as the itemRenderer. Set your columnCount on the TileList to 5.
              The dataProvider for pretty much any component needs to be just that...data.
              Not UIComponents.
              HTH;
              Amy
              • 4. Re: Why doesn repeater work inTileList?
                wyattbiker Level 1
                The itemRender idea worked, thank you. I used new ClassFactory(MyButton) class and made a separate custom MyButton component MXML source file.
                P.S. Any idea why the styleName property doesn't work with a custom component? I tried to set the style of a custom Button component and it doesn't show the colors/sizes in Flex.
                • 5. Re: Why doesn repeater work inTileList?
                  Level 7
                  news:ga5a54$8sr$1@forums.macromedia.com...
                  > component
                  > MXML source file.
                  > component?
                  > the
                  http://flexdiary.blogspot.com/2008/06/using-css-typeselector-with.html
                  http://flexdiary.blogspot.com/2008/08/tilelist-with-stylefunction.html
                  HTH;
                  Amy
                  • 6. Re: Why doesn repeater work inTileList?
                    wyattbiker Level 1
                    I found out I can set the styleNameon the TileList component. Saves me the headache.
