4 Replies Latest reply on Sep 5, 2008 5:35 AM by aruvasavi
    Acceesing problem
    aruvasavi
      Hi
      Following is my peace of code...
      <mx:TabNavigator x="0" y="0" width="1000" height="800" >
      <mx:Canvas label="DASHBOARD" width="100%" height="100%" id="DASHBOARD">
      <mx:Button x="119" y="243" label="PAN" id="PAN"/>
      <mx:Button x="119" y="309" label="ZOOM" id="ZOOM"/>
      </mx:Canvas>
      </mx:TabNavigator>
      In my action script "PAN.enabled = false;" is not working!!
      How to disable PAN button in Action script!! What's wrong with it!!
      How to proceed to disable PAN button in AS3????
      Thanks in Advance
      Aruna.S.N.
        • 1. Re: Acceesing problem
          dietmar.paulus Level 1
          Hey
          there is nothing wrong with your code, it just belongs where you write your actionscript code.
          if you write it in the scrrpt-Tag which is in the same file than the tabNavigator with the canvas and the buttons, this code will work without any problem, but if you want to enable the PAN-Button outside this component (in another as or mxml-File) you cannot reference to PAN. Therefore you should use the getChildByName()-methods
          cheers
          dietmar
          • 2. Re: Acceesing problem
            aruvasavi Level 1
            My peace of MXML and XML file is as follows...
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute"
            initialize="initializeHandler();">
            <mx:XML id="tempXML"
            source="assets/access.xml"/>
            </mx:Canvas>
            </mx:TabNavigator>
            <mx:Script>
            <![CDATA[
            private function initializeHandler():void
            if( tempXML.group[0].name == "Security"){
            if(tempXML.group .noaccess1 == "PAN")
            XML file is as below...
            <Menu>
            <group>
            <name>Security </name>
            <noaccess1>PAN</noaccess1>
            <noaccess2>TILT</noaccess2>
            <noaccess3>ZOOM</noaccess3>
            <noaccess4>PATROL</noaccess4>
            <noaccess5>TOPOLOGY</noaccess5>
            <noaccess6>CONFIGURATION</noaccess6>
            <noaccess7>ADMIN</noaccess7>
            </group>
            </Menu>
            Whats wrong with it???
            Thanks n Regards
            Aruna.S.N.
            • 3. Re: Acceesing problem
              SujitG Level 2
              Please try invoking the initializeHandler function in creationComplete event rather than initialize event. In the initialize event, I don't think the children components are created.
              Hope this helps.
              • 4. Re: Acceesing problem
                aruvasavi Level 1
                Yes it is really helpful for me!!
                Thank u very much 4 the answer!!
                Thanks n Regards
                Aruna.S.N.
