4 Replies Latest reply on Apr 7, 2009 7:33 AM by jbenson@oper8
    error 100: Application descriptor cannot be parsed
      error 100: Application descriptor cannot be parsed..i am a novice in adobe air.can someone tell me how to resolve this error
        • 1. Re: error 100: Application descriptor cannot be parsed
          jbenson@oper8 Level 2
          Can you post the contents of your application descriptor xml file?
          • 2. Re: error 100: Application descriptor cannot be parsed
            tzeng Adobe Employee
            Something wrong with your Application descriptor file.
            -ted
            • 3. Re: error 100: Application descriptor cannot be parsed
              Level 1
              <?xml version="1.0" encoding="utf-8" ?>
              <application xmlns="http://ns.adobe.com/air/application/1.5">
                <filename>Test1</filename>
                <programMenuFolder>FirstApplication</programMenuFolder>
                <customUpdateUI>false</customUpdateUI>
                <id>Test1</id>
                <version>1</version>
                <initialWindow>
                  <content>index.html</content>
                  <height>350</height>
                  <width>250</width>
                  <systemChrome>standard</systemChrome>
                  <transparent>false</transparent>
                  <visible>true</visible>
                </initialWindow>
                        <icon>
                          <image128x128>icons/1.png</image128x128>
                          <image48x48>icons/2.png</image48x48>
                          <image32x32>icons/3.png</image32x32>
                          <image16x16>icons/4.png</image16x16>
                      </icon>
              </application>
              • 4. Re: error 100: Application descriptor cannot be parsed
                That's interesting, your application descriptor runs in the AIR debug launcher (adl).
                A suggestion, start a bit smaller, add lines and see what is causing the error.
                Try this one
                <?xml version="1.0" encoding="UTF-8"?>
                    <filename>FirstApplication</filename>
                    <id>AirTest.html.FirstApplication</id>
                    <version>0.1</version>
                    <name>FirstApplication</name>
                    <installFolder>FirstApplication</installFolder>
                    <initialWindow>
                        <width>250</width>
                    </initialWindow>
                </application>
                If it works then add new parameters and retry (like Icon, customUpdateUI etc).
                A question:  Are you trying to build the application, debug the application or via Actionscript or Javascript, parse the application descriptor file?
