0 Replies Latest reply on Apr 6, 2009 12:49 AM by essa tkinen
    dynamically populate a sort fields array?
    essa tkinen Level 1
      so i'm having a problem i want to make my sorting dynamic so which ever sorts are being used get put into the mySort.fields array. I don't no how to get sortsString(a comma delimted list) to excute before mySort.fields . Anybody got an idea? Its probably something stupid and small that i don't no
      private function applySort(item:String):void {
      var sorts:ArrayCollection = new ArrayCollection;
      var mySort:Sort = new Sort();
      trace(item);
      switch (item) {
      case 'mostViewsSort':
      var field1:SortField = new SortField("views", true,true,true);
      sorts.addItem('field1');
      break;
      case 'mostDownloadsSort':
      var field2:SortField = new SortField("downloads", true,true,true);
      sorts.addItem('field2');
      break;
      case 'adminRatingSort':
      var field3:SortField = new SortField("adminRating", true,true,true);
      sorts.addItem('field3');
      break;
      case 'userRatingSort':
      var field4:SortField = new SortField("userRating", true,true,true);
      sorts.addItem('field4');
      break;
      var sortsString:String = String(sorts);
      mySort.fields=[sortsString];         // getting an error here if I just put in field1 it works fine but i want to apply field1,field2 etc if user wants it and that gets stored in the sorts array and gets put into sortsString as a comma delimted list.
      _videos.sort = mySort;
      _videos.refresh();
      sorts.removeAll();
